[GRASS5] mingW: how to exclude win32_pipes.c & user_config.c from compilation?
we have to exclude compilation of
lib/gis/win32_pipes.c
lib/gis/user_config.c
when compiling with mingW. How to modify the Makefile?
Is there a way to define an EXCLUDE variable in this
Makefile and make include/Make/Lib.make aware of it?
I know too little about Makefile programming to implement
it correctly. Throwing files away may not be the solution.
Huh? The whole of win32_pipes.c is conditionalised upon
"#ifdef __MINGW32__", so if that file isn't wanted for MinGW, it
should just be removed.
The usual approach is to just conditionalise the entire source file
upon a macro, so that you effectively get an empty file if the test is
false.
false.
I don't know - this was a request by Radim, I suggested
to him to remove the files. Let's listen to him.
> false.
Those two files do not compile with MinGW but they are not
used in fact. The files were not in the list of files for compilation
in Makefile but with the recent change which is using *.c
appeared in the list. I only want that it compiles. Do whatever
you prefer. I just worry that if we delete the files the code will be
forgoten for ever.
Radim
> > false.
forgoten for ever.
ISTR that win32_pipes.c is supposed to be replacements for
unix_socks.c, as Windows doesn't support PF_LOCAL (aka PF_UNIX)
sockets.
Personally, I would have thought it would be simpler to just use a
PF_INET socket instead (e.g. use an ephemeral port and write the port
number to a file with the same pathname as would have been used for
the PF_LOCAL socket).
Do you have any idea why they don't compile under MinGW? Both appear
to have been explicitly written with MinGW in mind. Maybe we need some
additional compilation options?
> > > false.
> forgoten for ever.
sockets.
user_config.c:34:17: pwd.h: No such file or directory
user_config.c: In function `_make_toplevel':
user_config.c:87: warning: implicit declaration of function `lstat'
user_config.c:94: error: too many arguments to function `mkdir'
user_config.c: In function `_make_sublevels':
user_config.c:246: error: too many arguments to function `mkdir'
OBJ.i586-pc-mingw32msvc/win32_pipes.o(.text+0x62): In function
`G_pipe_get_fname':
/ssi0/ssi/blazek/win/source/grass6/lib/gis/win32_pipes.c:66: undefined
reference to `_lstat'
OBJ.i586-pc-mingw32msvc/win32_pipes.o(.text+0x166): In function `G_pipe_exists':
/ssi0/ssi/blazek/win/source/grass6/lib/gis/win32_pipes.c:142:
undefined reference to `_CloseFile'
Radim
> > > > false.
> > forgoten for ever.
> sockets.
see make_loc.c:
#ifdef __MINGW32__
# define mkdir(name, mode) ((mkdir) (name))
#endif
`G_pipe_get_fname':
Radim
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
  #ifndef __MINGW32__
  #include <pwd.h>
  #endif
The code which relies upon <pwd.h> is already conditionalised upon
__MINGW32__.
