[GRASS5] Misc. Module Errors
Here are the rest of the modules that fail to compile and their error(s):
Both "src/mapdev/v.geom/cmd" and "src/misc/m.clump" get this error:
  /usr/bin/ld: Undefined symbols:
  _GLOBAL_INTERRUPT_ALGORITHM
  _gcvt
  GISGEN failure at STEP: src/mapdev/v.geom
v.in.shape reported an error that it could not access malloc.h, so after copying malloc.h from "/System/Library/Frameworks/System.framework/Versions/B/Headers/bsd/sys/" to "src/include/" it only gets one error:
/usr/src/grass/src/mapdev/v.in.shape
make -f OBJ.powerpc-apple-darwin1.2/make.rules
cc -g -O2 -I/usr/src/grass/src/include -c shp2dig.c -o OBJ.powerpc-apple-darwin1.2/shp2dig.o
shp2dig.c:807: illegal expression, found `}'
make: *** [OBJ.powerpc-apple-darwin1.2/shp2dig.o] Error 1
/usr/src/grass/src/mapdev/v.rmdup/cmd
cc -g -O2 -I/usr/src/grass/src/include -c rmdup.c -o OBJ.powerpc-apple-darwin1.2/rmdup.o
rmdup.c: In function `killdups':
rmdup.c:196: structure has no member named `_shortbuf'
make[1]: *** [OBJ.powerpc-apple-darwin1.2/rmdup.o] Error 1
make: *** [all] Error 2
/usr/src/grass/src/raster/r.in.gdal
cc -o /usr/local/grass5/etc/bin/main/cmd/r.in.gdal OBJ.powerpc-apple-darwin1.2/main.o OBJ.powerpc-apple-darwin1.2/gbgetsymbol.o OBJ.powerpc-apple-darwin1.2/gdalbridge.o OBJ.powerpc-apple-darwin1.2/make_loc.o /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libI.a /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a \
_GBGetSymbol
make: *** [/usr/local/grass5/etc/bin/main/cmd/r.in.gdal] Error 1
/usr/src/grass/src/raster/r.mapcalc/mapcalc
  _drand48
  make[1]: *** [/usr/local/grass5/etc/bin/main/cmd/r.mapcalc] Error 1
  make: *** [all] Error 1
/usr/src/grass/src/raster/r.random
_lrand48
_srand48
make: *** [/usr/local/grass5/etc/bin/main/cmd/r.random] Error 1
/usr/src/grass/src/sites/s.kcv
  _drand48
  _srand48
  make: *** [/usr/local/grass5/etc/bin/contrib/cmd/s.kcv] Error 1
/usr/src/grass/src/sites/s.random
  main.c: In function `main':
  main.c:127: `drand48' undeclared (first use in this function)
  main.c:127: (Each undeclared identifier is reported only once
  main.c:127: for each function it appears in.)
  make: *** [OBJ.powerpc-apple-darwin1.2/main.o] Error 1
/usr/src/grass/src/sites/s.to.rast
main.c:251: illegal expression, found `}'
main.c:335: illegal expression, found `}'
/usr/src/grass/src.garden/answers/src.answers/raster/r.fill.dir/cmd
c fmt_un.f -o OBJ.powerpc-apple-darwin1.2/fmt_un.o
make[1]: c: Command not found
make[1]: [OBJ.powerpc-apple-darwin1.2/fmt_un.o] Error 127 (ignored)
OBJ.powerpc-apple-darwin1.2/fmt_un.o -o /usr/local/grass5/etc/fill/fmt_un
make[1]: OBJ.powerpc-apple-darwin1.2/fmt_un.o: Command not found
make[1]: *** [/usr/local/grass5/etc/fill/fmt_un] Error 127
src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc
  _drand48
  make[4]: *** [/usr/local/grass5/etc/bin/main/cmd/r3.mapcalc] Error 1
  make[3]: *** [all] Error 1
  make[2]: *** [all] Error 2
  make[1]: *** [all] Error 1
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
  _gcvt
Well, I think this command must be moved out of default build anyway
(license problem).
malloc.h should be part of the Standard C lib. I'm thinking there must
be a problem somewhere between the C preprocessor, and the compilation
phase. Based on your other error reports, it would seem various macros
in included header files may not be getting expanded correctly, and
hence generating errors. All the 'illegal expression, found }' lead me
to believe that some kind of expansion is happening in the preprocessor
that is generating illegal code for the compiler. Also, could be this
thing with the switch construct (see below).
/usr/src/grass/src/mapdev/v.in.shape make -f
OBJ.powerpc-apple-darwin1.2/make.rules cc -g -O2
OBJ.powerpc-apple-darwin1.2/shp2dig.o shp2dig.c:807: illegal
expression, found `}' make: ***
/usr/src/grass/src/mapdev/v.rmdup/cmd make -f
OBJ.powerpc-apple-darwin1.2/rmdup.o rmdup.c: In function `killdups':
rmdup.c:196: structure has no member named `_shortbuf' make[1]: ***
[OBJ.powerpc-apple-darwin1.2/rmdup.o] Error 1 make: *** [all] Error 2
/usr/src/grass/src/raster/r.in.gdal make -f
/usr/bin/ld: Undefined symbols: _GBGetSymbol make: ***
/usr/src/grass/src/raster/r.mapcalc/mapcalc usr/bin/ld: Undefined
symbols: _drand48 make[1]: ***
[/usr/local/grass5/etc/bin/main/cmd/r.mapcalc] Error 1 make: *** [all]
Error 1
I think these drand errors are a problem with Architecture specific
macros which choose between inclusion/exclusion of various random number
generators that may/may not be available. The code probably needs some
additions to the "guards" for deciding to use drand48 or rand or
whatever. Do you happen to know what the unique architechture symbol is
that is defined for Mac OS X? It should be something like __MAC_OS_X__;
similar symbols are __AIX__, __CYGWIN__. If you find out, we may be
able to add it to appropriate places.
/usr/src/grass/src/raster/r.random /usr/bin/ld: Undefined symbols:
_lrand48 _srand48 make: ***
  /usr/bin/ld: Undefined symbols: _drand48 _srand48 make: ***
  main.c: In function `main': main.c:127: `drand48' undeclared (first
  use in this function) main.c:127: (Each undeclared identifier is
  reported only once main.c:127: for each function it appears in.)
/usr/src/grass/src/sites/s.to.rast main.c:251: illegal expression,
found `}' main.c:335: illegal expression, found `}' make: ***
Well at least this one is maybe again a case of an empty 'default:'
statement in a switch(){} construct. I just added a 'break;', but I
believe we covered similar ground before elsewhere, and still believe
the compiler has a bug about this.
c fmt_un.f -o OBJ.powerpc-apple-darwin1.2/fmt_un.o make[1]: c: Command
not found make[1]: [OBJ.powerpc-apple-darwin1.2/fmt_un.o] Error 127
(ignored) OBJ.powerpc-apple-darwin1.2/fmt_un.o -o
/usr/local/grass5/etc/fill/fmt_un make[1]:
OBJ.powerpc-apple-darwin1.2/fmt_un.o: Command not found make[1]: ***
[/usr/local/grass5/etc/fill/fmt_un] Error 127 make: *** [all] Error 1
This requires a fortran compiler. Do you have one? Appears the
FC = @F77@ in src/CMD/head/head.in is set to 'c', which is gibberish.
  /usr/bin/ld: Undefined symbols: _drand48 make[4]: ***
  [/usr/local/grass5/etc/bin/main/cmd/r3.mapcalc] Error 1 make[3]: ***
  [all] Error 1 make[2]: *** [all] Error 2 make[1]: *** [all] Error 1
Eric G. Miller <egm2@jps.net>
Hi Jeshua,
one addition to the comments of Eric:
r.in.gdal depends on the gdal library.
It is IMHO dynamically linked to this library, so that it would be safe
to exclude it for your build _or_ include the gdal library too.
To the list: We should discuss if we include the gdal library for the
GRASS5.0stable version.
cu,
Andreas
_GBGetSymbol
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange@Rhein-Main.de - A.C.Lange@GMX.net
Hi Jeshua,
  _gcvt
-> both are currently moved to unused.
Hi David :slight_smile:
Fixed. See other message.
_GBGetSymbol
This is a problem on Irix, too. We need Frank Warmerdam for that.
  _drand48
Fixed, please try from CVS.
_lrand48
_srand48
  _drand48
  _srand48
Eric, may I ask you to check for this? You already managed something
like this (even if it is a compiler bug).
Requires F77/g77 compiler.
  _drand48
Hope this helps again (it's unbelievable that you compiled this
in beta8... nothing changed.)
