[GRASS5] Misc. Module Errors
On Tuesday, December 12, 2000, at 01:13 AM, Markus Neteler wrote:
I need little assistance:
MacOS X behaves similar to CYGWIN. I have added
MacOSX sensivity to some "rand" definitions, unfortunately
the compiler doesn't understand:
#if defined(__CYGWIN__) || defined(__MAC_OS_X__)
How to find out the correct definition for Jeshua's Mac OS X?
__MAC_OS_X__ is not accepted. We need to tell Jeshua where
to search for this string.
Then I will fix below problems.
Thanks
Hi Markus!
I do not now if this is any help but the following environment variables are defined in Mac OS X:
HOSTTYPE=macintosh
VENDOR=apple
OSTYPE=macos
MACHTYPE=powerpc
Maybe you could check for $OSTYPE??
On Mon, Dec 11, 2000 at 03:05:29PM -0800, Jeshua Lacock wrote:
> On Monday, December 11, 2000, at 06:23 AM, Markus Neteler wrote:
> > > /usr/src/grass/src/raster/r.mapcalc/mapcalc
> > > usr/bin/ld: Undefined symbols:
> > > _drand48
> > > make[1]: *** [/usr/local/grass5/etc/bin/main/cmd/r.mapcalc] Error 1
> > > make: *** [all] Error 1
> > Fixed, please try from CVS.
> I updated, and I still get the same error.
> I did not re-run configure, though, should I??
> > > /usr/src/grass/src/raster/r.random
> > > /usr/bin/ld: Undefined symbols:
> > > _lrand48
> > > _srand48
> > > make: *** [/usr/local/grass5/etc/bin/main/cmd/r.random] Error 1
> > > /usr/src/grass/src/sites/s.kcv
> > > _drand48
> > > _srand48
> > > make: *** [/usr/local/grass5/etc/bin/contrib/cmd/s.kcv] Error 1
> > > /usr/src/grass/src/sites/s.random
> > > main.c: In function `main':
> > > main.c:127: `drand48' undeclared (first use in this function)
> > > main.c:127: (Each undeclared identifier is reported only once
> > > main.c:127: for each function it appears in.)
> > > make: *** [OBJ.powerpc-apple-darwin1.2/main.o] Error 1
> > > /usr/src/grass/src/sites/s.to.rast
> > > main.c:251: illegal expression, found `}'
> > > main.c:335: illegal expression, found `}'
> > Eric, may I ask you to check for this? You already managed something
> > like this (even if it is a compiler bug).
> I got it to compile by adding a 1 at the default switches ar lines 251 and 335 (The comments
said that it should never be used, so I assume this hack is OK?)
> > > /usr/src/grass/src.garden/answers/src.answers/raster/r.fill.dir/cmd
> > > make -f OBJ.powerpc-apple-darwin1.2/make.rules
> > > c fmt_un.f -o OBJ.powerpc-apple-darwin1.2/fmt_un.o
> > > make[1]: c: Command not found
> > > make[1]: [OBJ.powerpc-apple-darwin1.2/fmt_un.o] Error 127 (ignored)
> > > OBJ.powerpc-apple-darwin1.2/fmt_un.o -o /usr/local/grass5/etc/fill/fmt_un
> > > make[1]: OBJ.powerpc-apple-darwin1.2/fmt_un.o: Command not found
> > > make[1]: *** [/usr/local/grass5/etc/fill/fmt_un] Error 127
> > Requires F77/g77 compiler.
> I can't get F77 compiled. Someone is working on the gcc port for Mac OS X. I guess it will
have to wait until then.
> > > src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc
> > > _drand48
> > > make[4]: *** [/usr/local/grass5/etc/bin/main/cmd/r3.mapcalc] Error 1
> > > make[3]: *** [all] Error 1
> > > make[2]: *** [all] Error 2
> > > make[1]: *** [all] Error 1
> > > make: *** [all] Error 2
> I updated, and I get a similar error:
> _drand48
> make: *** [/usr/local/grass5/etc/bin/main/cmd/r3.mapcalc] Error 1
> > Hope this helps again (it's unbelievable that you compiled this
> > in beta8... nothing changed.)
> Thanks for the help. These modules were not compiled with my beta 8 binaries (I gave up on
them)....
> Yours,
> Jeshua Lacock
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
Hi jeshua and Markus
> Thanks
> Markus
Hi Markus!
HOSTTYPE=macintosh
VENDOR=apple
OSTYPE=macos
MACHTYPE=powerpc
I don't know about other compilers but MIPSPro compilers have a -show
option which lists the variables defined by the compiler. Check the man
page to see if such an option exists for your compiler.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
