[GRASS5] Modules in C++?
Hi GRASS Gurus,
I have started tinkering with GRASS, and in this process of learning a
bit about
grass, I would like to be able to learn a little more about C++.
Now I know that the programming standard for GRASS is to use C, not C++.
Is it possible for, for my purposes, to work with C++ not C, and what
needs to be done?
Does it require largescale mucking around with gmake?
Matt Redding
********************************DISCLAIMER****************************
The information contained in the above e-mail message or messages
(which includes any attachments) is confidential and may be legally
privileged. It is intended only for the use of the person or entity
to which it is addressed. If you are not the addressee any form of
disclosure, copying, modification, distribution or any action taken
or omitted in reliance on the information is unauthorised. Opinions
contained in the message(s) do not necessarily reflect the opinions
of the Queensland Government and its authorities. If you received
this communication in error, please notify the sender immediately and
delete it from your computer system network.
bit about
needs to be done?
It's possible, but:
1. You need to use the code from the CVS HEAD; neither the release
branch nor any of the release tarballs support C++.
2. Your C++ compiler needs to be highly compatible with your C
compiler, as the same compilation switches are used regardless of
language.
3. The GRASS header files aren't compatible with C++, so you need to
wrap any #include directives, e.g.:
  extern "C" {
  #include <gis.h>
There may be other issues.
