[GRASS5] Monitor Bug? (Mac OS X)
Greetings all,
First off I would like to mention that I now have Grass running in "rootless XWindows mode" in Mac OS X, complete with drop shadows and all - for a screen shot point your browser to: http//OpenOSX.com/grass. Very cool! I am going to install a window manager next...
I have been testing Grass5 pre1's GUI and I have uncovered an (apparent) bug, both in the new rootless and tried and true full screen mode. I started a monitor, choose "Quit", with the option "save config", and hit "OK". The GUI will no longer start for this user, I tried deleting the .grassrc5 file and still no go.
When I launch grass5, the location chooser works, then the menu bar appears and states that it is "Loading...", I am prompted to position the monitor location, after I click I get the error (I created a new user and all is well - with the new user):
Error in startup script: Warning: locale not supported by C library, locale unchanged
     while executing
"exec xterm -geometry 40x5 -e d.mon start=$monitor"
     (procedure "start_monitor" line 17)
     invoked from within
"start_monitor $name"
     (procedure "start_monitors" line 5)
     invoked from within
"start_monitors"
     (file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1897)
     invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
     (file "/usr/local/grass5/bin/tcltkgrass" line 17)
I am pretty sure the problem has to do with (re)creating the Monitor. Any idea how to zap the "preference" that starts the monitor?
Jeshua Lacock http://OpenOSX.com
Cartographer/Owner http://SierraMaps.com
Phone: (760) 935-4481 http://3dTopoMaps.com
On Fri, Jul 06, 2001 at 03:31:23PM -0700, jeshua wrote:
[snip]
The tcltkgrass GUI has its own resource configuration file ~/.tcltkgrass
locale unchanged
     while executing
Does "xterm" work otherwise? Seems the problem is with xterm not liking
the locale setting.
Yes, but it looks like it's with the xterm and your locale setting.
Looks like using "xterm" is pretty hard-wired into tcltkgrass. It
should probably be using $TERM first.
Eric G. Miller <egm2@jps.net>
> locale unchanged
> while executing
the locale setting.
No; $TERM is the current terminal's type, for the purpose of locating
the correct termcap or terminfo entry. It isn't the name of the user's
preferred terminal emulator program.
It may well be a good idea to provide an environment variable for this
purpose (analogous to EDITOR), but it shouldn't be TERM, or use $TERM
as its default.
