I have a question. I remember I was able to resize the XDRIVER monitor
by dragging the edge of the window with mouse. But now I cannot, maybe
from 6.0 (?). Is this intended (then why?) or a window manager problem?
I know there is d.resize, but it's sometimes inconvenient.
You cannot resize the window while a client is connected. The
dimensions which the driver reports to the client must remain correct
for the lifetime of the client.
However, there have been reported problems with some window managers
refusing to allow resizing even when no client is connected. The most
likely reason is that they are recording the min/max size which are
set while a client is connected then continuing to enforce the
restrictions after they are removed.
One thing to try is to change:
szhints->flags = PSize;
to:
szhints->flags = 0;
on line 24 of display/drivers/XDRIVER/XDRIVER24/Client.c, and/or
changing:
szhints->flags = USSize;
to:
szhints->flags = 0;
on line 205 of display/drivers/XDRIVER/XDRIVER24/Graph_Set.c.
Let me know how this works out; the existing code works OK with all of
the window managers which I have tried.
> monitor by dragging the edge of the window with mouse. But now I
> cannot, maybe from 6.0 (?). Is this intended (then why?) or a
> window manager problem? I know there is d.resize, but it's sometimes
> inconvenient.
to:
szhints->flags = 0;
changing:
to:
szhints->flags = 0;
Using the Fluxbox WM (~1 year old version) on Debian:
The resizing control (and window border) are there when you first create
the window with d.mon, but disappear as soon as you call anything (eg
d.erase). `d.mon stop=xN && d.mon start=xN` doesn't always bring them
back unless you start/stop a different number monitor first.
The above two code changes don't have any affect, AFAICT.
Are there any verbose xwininfo options that may be of help for checking
the window's state?
> > inconvenient.
> to:
> szhints->flags = 0;
> changing:
> to:
> szhints->flags = 0;
The exact same things happened to me. I'm working around this problem with a
dirty script:
#!/bin/sh
start=0
if echo $@ | grep 'sta.*=' > /dev/null 2>&1
then
start=1
mon=`echo $@ | sed 's/^.*=//'`
elif ! echo $@ | grep '=' > /dev/null 2>&1
then
if ! echo $@ | grep 'help' > /dev/null 2>&1
then
start=1
mon=$@
fi
fi
if [ $start -eq 1 ]
then
d.mon -s $mon
sleep 1
d.mon select=$mon
else
d.mon $@
fi
This script is aliased to d.mon.
the window's state?
the window's state?
xprop will list the properties associated with a window. The
WM_NORMAL_HINTS property is the one which normally controls resizing.
> > all of the window managers which I have tried.
> create the window with d.mon, but disappear as soon as you call
> anything (eg d.erase). `d.mon stop=xN && d.mon start=xN` doesn't
> always bring them back unless you start/stop a different number
> monitor first.
> checking the window's state?
First off, I'd mention that 'd.mon sel=x0' does as good a job of losing
the frame (and resizing ability) as d.erase or any other display
command. So to keep things simple I've used that to trigger it.
Working case (GNOME + Sawfish WM + Debian's XFree86 4.3):
`xprop`:
WM_NORMAL_HINTS(WM_SIZE_HINTS):
program specified size: 585 by 720
`xprop -spy` as `d.mon sel=x0` is executed:
program specified minimum size: 585 by 720
program specified maximum size: 585 by 720
Failing case (Fluxbox WM + XFree86 4.2.1):
`xprop`:
[nothing, next item]
program specified minimum size: 640 by 480
program specified maximum size: 640 by 480
No diff between before and after states as shown by xwininfo and xprop
when `d.mon sel=x0` is run triggering presence/absence of frame.
