[GRASS5] monitor resize
I have a question. I remember I was able to resize the XDRIVER
monitor by dragging the edge of the window with mouse. But now I
cannot, maybe from 6.0 (?). Is this intended (then why?) or a
window manager problem?
It should work. Try with another WM; are you using Fluxbox or something
more exotic?
Hamish
____________________________________________________
Start your day with Yahoo! - make it your home page
http://www.yahoo.com/r/hs
more exotic?
Resizing is disabled if you are using an interactive command
such as i.points etc. It get's enabled again once you leave the
command.
I tried twm, WindowMaker, Fluxbox, evilwm, ion, wmi2, ...
twm, evilwm, wmi2: resizing works
WindowMaker, Fluxbox, ion: resizing doesn't work
It depends on which WM I use. Does this mean that some WMs ignore the
USSize hint? Or is the USSize hint supposed to not allow WM to resize the
window? If this is the latter case, I think XDRIVER should be fixed.
Huidae Cho
more exotic?
Hamish
When a client connects, the WM_NORMAL_HINTS property is updated to
include minimum and maximum size settings (PMinSize, PMaxSize) equal
to the current window size, to prevent the window from being resized
while a client is using it. Once the client disconnects, the min/max
size settings are removed.
With some window managers, the min/max settings appear to "stick".
As a quick test:
1. Start the monitor with the "-s" switch, which prevents mon.select
from being run; at that point, the min/max size settings will never
have been applied.
2. Try resizing the monitor.
3. Run "d.mon select=...", which will connect to the monitor, causing
the min/max size settings to be applied and removed.
4. Try resizing the monitor again.
1. d.mon -s start=x0
2. d.mon select=x0
3. Resizing works!
But,
1. d.mon -s start=x0; d.mon select=x0
2. Resizing doesn't work!
But!
1. d.mon -s start=x0; sleep 1; d.mon select=x0
2. Resizing works!
It's interesting! Maybe, WM doesn't have enough time to do something
when select is executed immediately after start.
Do you have any idea?
Huidae Cho
As a quick test:
have been applied.
2. d.mon select=x0
3. Resizing works!
But,
But!
2. Resizing works!
The difference between the second and third cases suggests that it's a
bug in the WM, as being able to resize should only depend upon the
current settings, not previous settings.
The properties start off with just USSize set. When a client connects,
they change to PSize|PMinSize|PMaxSize; when it disconnects, it
reverts to just PSize.
The one thing which will definitely fix it is to bypass the calls to
set_size(). But then the responsibility for ensuring that the window
isn't resized while a client is connected falls to the user.
