the problem which I described in last e-mail (d.vect disp=cat|attr where=)
is more complex (as I have found out using ps.map)...
The patch for d.vect, attached to the last e-mail, is faulty. It works only
if 'where' condition or category value is set. I forgot to check 'chcat' variable.
So there is modified patch for d.vect (d.vect-patch1.tar.gz),
I hope better than the last one...
I have similar problem with ps.map. I have tried to display centroids using where
condition. No points were displayed... For example:
one centroid/point
layer/cat
50/1
50/2
attribute table:
cat | kod
1 | 18
2 | 304
input for ps.map:
vpoints bylany_hp
type centroid
layer 50
where kod=304
symbol dkm/zahrada
color black
size 7
lpos 0
label
end
--> no points found ...
In function Vect_set_varray_from_db () is used Vect_cat_get () which
finds _first_ category of given field. So in this case category '1'!
For my purpose (I am trying to develop GRASS module for importing data in Czech
cadastre exchange data format -- my diploma thesis) I have modified this function
(see array.c.patch). But I am not sure if this solution is good...
Best regards,
Martin
Martin Landa <landa@gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
CTU Prague, Faculty of Civil Engineering, Czech Republic
(attachments)
array.c.patch (2.5 KB)
d.vect-patch1.tar.gz (1.13 KB)
