[GRASS5] more GRASS 5.7 testing under MacOSX
Getting ready for my class this semester, I downloaded and began testing GRASS 5.7 again. I am using the 20 November 2003 binaries that Markus has kindly made available. Some of these things may have been dealt with in the current CVS snapshot, but I haven't yet had the chance to try compiling it.
So far, I've seen a couple old bugs still in effect, and run into a new one. Also, given that the new version is overall quite stable and potentially useful, I want to add two requests.
1. Nviz still doesn't work. Trying to start it returns an error that nviz2.2_script can't be found (even though it is indeed located in the proper place). I tried to force run the script from within grass, but it crashed before it started with several errors. If anyone is interested, I can send these. I don't know if this is because Nviz doesn't work with 5.7 yet, or it is a bug in the startup script.
2. In the display manager, when reorganizing the different map layers, dragging a layer a little too far (it doesn't take much) below the bottom-most layer starts an endless error loop that can only be exited by crashing out of GRASS.
3. This may be new. d.what.vect is not functioning correctly. In normal mode, it is supposed to return a new tcltk monitor with information about fields that can be changed if needed. This does not happen. If I am lucky, nothing happens; if unlucky, d.what.vect crashes with a problem with child process error. I CAN get information about a vector if I select the option to display it as text in a terminal window. Toggling flash and exit functions seem to work fine.
4. Request. Can a menu system be made for the majority of the commands--as in version 5.0.x? It could be pull downs across the top (as in prior GRASS versions), along the side (as in ArcInfo and some CAD programs), or floating pallets like in GIMP. I just can remember ALL the commands.
5. The dialogs for the g.* (general) commands all seem to lack browse buttons. Can browse buttons be added?
I think this is a very good and exciting product. I am strongly suggesting it for the graduate students here.
Thanks very much
Michael
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Michael,
in 5.7, due to the above mentioned (path) problem NVIZ only runs
via command line:
nviz el=elevation vect=vect1[,vect2[,...]] [col=draperastermap]
One day we'll solve that...
Yes, a bad problem! I also face it.
Yes, done for g.copy, g.rename, g.remove (in 5.7 CVS). Do you
think of any other command?
Great - hopefully they enjoy it,
