Going through BUGS list again...
d.param.scale:
Removed? Related to removal of optri?
d.rast.edit:
Seems to edit floating point just fine.
d.sites.qual:
Can we get some decision about whether this is or isn't a BUG.
(I vote that it isn't).
g.select.pg:
Think I fixed all that a few weeks back...
i.tape.tm.fast:
Think it's fixed, but I can't really test without tape drive and TM
imagery. It get's past segfault in interactive...
r.in.hdf/r.out.hdf:
I didn't see anything in the hdf dirs indicating any version for hdf5.
I'd recommend not including the HDF5 library with GRASS sources should
such a thing ever come to be. Such a thing should just use the shared
library (if present, else no compile).
r.los:
Should we just have it exit for lat/lon rasters/databases? I'm not
sure how to handle the metrics (what would the elevation units be?).
r.null:
I still think the behavior about reclass maps is right.
r.out.tiff:
The -t flag problem should be fixed now. The NULL color thing is
kind of fixed. This module really needs a ground up rewrite.
r.rescale:
Agree with Andreas on Zero vs. NULL thing.
That's enough for now
Eric G. Miller <egm2@jps.net>
subject 'unsubscribe grass5'
