[GRASS5] most recent snapshot
Glynn wrote:
Can you provide error messages? Building NVIZ is complicated by
depending upon OpenGL and Tcl/Tk, both of which have variations
depending upon platform and version.
This mail client only allows me to send such things as attachments. I
ran gmake5 in the NVIZ2.2 directory and attached the last part of the
file.
Can you tell whether the snapshot is based upon the (now defunct)
release branch, or the head? If there are any "CVS/Tag" files, it's
the release branch.
There is a tag file. It contains
Treleasebranch_11_april_2001_5_0_0
I made some changes in that area. Basically, I changed the invocation
of lex and yacc so that they use the default filenames (lex.yy.c,
y.tab.[ch]). These are the files which the "maintainer-clean" target
now removes. If the snapshot was installed over an existing
directory,
or if "make maintainer-clean" wasn't run prior to creating the
snapshot, that might cause problems.
As it happens, I did install it over my pre2 release. I didn't expect
to, but I had a soft link from "grass" to "grass5.0.0pre2". The top
level directory in the tar ball was named "grass" so when I unpacked the
tar ball it installed on top of my pre2 installation. I lost some work
because of that, but it was my own fault.
It would have been nice if the tar ball had a non-generic name for it's
top-level directory like the normal tar ball releases do.
Anyway, I did a "make distclean" on the pre2 directory before I
installed the snapshot over it, not "make maintainer-clean".
Roger Miller
(attachments)
log (693 Bytes)
file.
make[1]: *** No rule to make target `sed', needed by `nvwish'. Stop.
make[1]: Leaving directory `/home/roger/grass5.Mar_22_2002/src.contrib/GMSL/NVIZ2.2/src'
That may also be due to a bad snapshot (or possibly installing over an
existing source tree). It's part of the same changes to the build
system as the lex/yacc issue. NVIZ2.2/src/Gmakefile used to be built
from Gmakefile.in by the NVIZ2.2/doconfigure script.
src/Gmakefile.in used to contain:
  NVWISH_VER=sed
  PQ_OBJS=sed
These lines were re-written (using sed) by the doconfigure script. The
resulting src/Gmakefile would typically contain something like:
  NVWISH_VER=NVWISH2.2
  PQ_OBJS=openvect.o getCat.o buildInfxQry.o runInfxQry.o
It appears that your src/Gmakefile has a bogus setting for PQ_OBJS.
> the release branch.
The release branch was terminated shortly after that snapshot was
created. AFAIK, the change delayed the production of snapshots,
resulting in the most recent snapshot being older than usual.
> now removes. If the snapshot was installed over an existing directory,
I'd agree with that.
"cvs update" will remove any files which have since been deleted, but
extracting over an existing version won't.
Can whoever maintains the snapshot build system (Markus?) change it to
generate a unique directory name for the snapshot, to prevent this
from happening.
"make maintainer-clean" performs "make distclean", but also deletes
the files which are generated by lex/yacc. These files aren't stored
in the repository; I don't know whether they are included in the
snapshots.
Also, the main batch of build changes were committed on 2002/02/20,
but I didn't fix the maintainer-clean target until 2002/02/21, which
could have resulted in a bogus snapshot being built. The dates are
suspiciously close to that of the snapshot.
Unfortunately, part of the problem with snapshots is that they may
contain code which has only just been committed to the repository,
before anyone other than the author is able to test it.
> > from happening.
> Now I have reached this mail while cleaning the box. Yes, I can change that,
> any suggestion for a unique directory name?
I meant something which would change with each snapshot, using the
date, e.g.:
  dirname=`date '+grass_%Y_%m_%d'`
O.k., I have changed all scripts. Now the snapshot tarballs contain
a unique directory, e.g.
tar tvfz grass50src_cvs_snapshot_exp_2002_04_17.tar.gz
-rw-r--r-- neteler/grass 4759 2002-03-01 05:12:19 grass50_exp_2002_04_17/aclocal.m4
drwxr-xr-x neteler/grass 0 2002-02-13 11:35:25 grass50_exp_2002_04_17/ALPHA64/
drwxr-xr-x neteler/grass 0 2002-02-13 11:35:25 grass50_exp_2002_04_17/ALPHA64/CVS/
... the same for 5.1.
Very good.
About the name. I do not think that "exp" is needed as a name component.
(It does not hurt otherwise, so this is just remark for future namings.)
A cvs_snapshot from the development branch of the stable tree
should not be called "exp". In fact there are no stable
cvs_snapshot. They are all experimental. :slight_smile:
Also note that all 5.1.x tarballs, cvs_snapshots or others things
will always be development and experimental.
This is a result of adopting the namin convention of the Linux-Kernel.
When we think we are reaching a stable state, we will rename it to 5.2.x.
  Bernhard
