[GRASS5] moving files with the mv command
To the Grass developers,
I have made a new binary distribution of the Grass5 beta
based upon the current CVS code and given it to Markus
for placement on the server
http://hgeo02.geog.uni-hannover.de/grass/grass5/binary/windows_cygnus/
The older May 24th one is still there at this time.
However, in reviewing the files in the distribution I noticed
some executables did not make it over to the /usr/local area.
I checked into the Gmakefiles and see that some of these
files depend on the existence of an a.out executable which
is then moved via the "mv" command to the /usr/local area.
Please do not do this. If you are creating new Gmakefiles
and makefiles, write the output target executable directly
to the $(GISBASE) area. The windows compilers create
files with a .EXE extension so the move fails. However,
if the target is specified correctly, then all works fine. e.g.
PROG=$(GISBASE)/some_dir/myprog
$(PROG): myprog.c
    $(CC) $(CFLAGS) -o $@ myprog.c
This will correctly write out the executable to the /usr/local
area for both Unix and Windows.
Thank you,
John Huddleston, P.E.
Computer Engineer
USDA - NRCS
John.Huddleston@usda.gov
subject 'unsubscribe grass5'
