[GRASS5] Multiple attribute support in GRASS 5.1: some considerations (long)
During the last days I've spent some time thinking about new vector
capabilities in GRASS 5.1, and in particular for what concerns multiple
attribute support and DBMS integration. I would like to share my thougths
with you. Please forgive my english, I'm not used to write such a long text
and I don't have enogh time to consult a dictionary and a grammar :slight_smile:
In my opinion we should thinks first about what kind of functionality we want
to include in GRASS 5.1 before thinking what kind of data structure to adopt.
Here is a possible list of interesting features that one can hope to find
into a vector GIS:
A) ability to store multiple attributes and to have them showed by clicking
on a map, ability to choose which attribute to use when performing
computations on the map;
B) ability to support overlay operations on vector data (which means also to
join attribute tables) (overlay: intersection, erase, identity and so on, if
you're familiar with ARC/INFO);
C) ability to query maps both by spatial criteria, both on the attribute
values just like in a SQL query;
D) ability to relate attribute tables with some other non spatial information
(catastral map with id referring to a table describing the owners of each
parcel, and so on);
E) ability to make concurrent users to make modifications on the same data.
There may be other requests, of course, and I haven't considered 3D vector
data such as TIN, but I think they are enogh to explain my proposals.
I think that A) and B) are essential requirements if we want to claim that
GRASS is a vector GIS.
C) is so common among vector GIS that I would look with suspect to a GIS that
don't perform such an operation. D) and E) are usually offered by high end
systems in conjunction with a DBMS that sports spatial data extensions, and
may be offered by GRASS if OSVectDB would turn into a real system (I think
that now they are at a specification level).
Now, let's see what kind of data structure we can use in order to support A),
B), and C) functions.
To support only A) and B) plain files are a good solution until the number of
data involved is not high. There are many possibilities, but I think that DBF
files are a good solution. Why?
* they are binary files, so access is faster that ASCII files;
* they are quite standard, almost any spreadsheet can read them and most DBMS
  have some way to import them (well, at least for what concerns commercial
  DBMS);
* because they don't require any growth in our software base, we already have
  a library to access them: shapelib.
Althought shapelib has limited capabilities when it comes to manage dbf files
I think that it does what is needed. So we could store only one index
toghether with geometric data and have all attributes stored in the DBF file.
That'a a simple solutions, but it seems also effective when only A) and B)
requirement are considered.
If you consider also C) requirements DBF are not the best choice, since they
don't support access thru SQL language. I think that here a DBMS is
necessary, since we get the power of SQL queries for free. Berkeley DB is not
a solution because it doesn't support SQL. PostgreSLQ is, and thru
referential integrity capabilities it would allow us to support also E)
requirement. If we want to stick on DBF files we have to choose wheter to
build into GRASS a minimal SQL support by hand or not let the user perform
queries unless a real DBMS is used. A SQL support based on DBF files would
be anyway slow because one have to do a sequential scan on attribute files
whereas a DBMS can use indexes and a built in query optimizer.
A solution that is based on storing topologic information in our classic
files and attributes into a database (DBF or Postgres) seems to me a good
choice. But it's not enogh.
When it comes to give good support to overlay and spatial queries you also
have to think at a fast way perform them: spatial indexes are
the solutions, and there are some already made libraries that can build
R-trees... the spatial index would be stored in a sepate file. So, one file
for the topology, one file for attributes and one (optional) file for the
spatial index. Since performance is an optional, we could add spatial index
support later (say in GRASS 6) and do sequential scans in the meantime.
Now, I also would like to perform some criticts on site data:
* access is slow, mainly because they are kept in ascii format and because
  the data structure can vary from record to record (-> site format is now
  too flexible);
* site API is not the best part of the GIS library, in my humble opinion, but
  that is mainly due to the poor file structure.
Why treat line, polygon and point data in a different way? Wouldn't it be
possible, and more efficient, to store coordinates and an index into a binary
file and put all the attributes into a DBF file? Or in a table inside a DBMS?
Using binary files would give us a huge performance improvement, and to
smaller files. I've seen it a the GRASS Day 2001 in Trento, Italy, somone had
an implementation of a site API and format that stores all data in a binary
file that also happens to be a quadtree (a fast way to store and index point
data -> they performed spatial queries in a really fast way, it was
impressive). I think that he's willing to donate that API to GRASS, he
seemed only concerned about stability and code quality.
Using DBMS tables or DBF files every record would get the same attributes,
and we would have attributes names too -> this would also lead to a cleaner
site API.
You should also consider that this way line, polygon and site management
would share some code leading to a smaller gis library (that means also
smaller to mantain, a nice feature in the long run). This would also lead to
an easier attribute management when it comes to use polygon and site
data at the same time (I'm thinking about Voronoi diagrams, but also
to overlay between polygon and site data).
What are your opinions?
Regards
Andrea Aime
subject 'unsubscribe grass5'
Have you read grass51/doc/vector/vector.html? Probably not, so I would
recomend you to look at it because some related proposals are there
and some experimental code is written in grass51 (g51). For example d.vect
with where= (SQL where) is already working.
In general I agree with your ideas, only few comments.
into a vector GIS:
parcel, and so on);
No, dbf files are ascii !!!
DBMS > have some way to import them (well, at least for what concerns
commercial > DBMS);
That was one of reasons why I wrote simple dbf driver.
have > a library to access them: shapelib.
Yes, my driver is based on shapelib. For future we must either extend shapelib
bit or use some other external library.
dbf driver (g51) is based on simple SQL parser so that it works like
SQL database for limited subset of SQL statements.
For simple and small projects dbf driver should be enough and for larger
projects some other driver may be used (at this time only odbc available
but postgres driver should not be problem)
David is working on spatial indexes, which should be on level 3 access.
  too flexible);
site API.
I agree that sites data should be stored in vector files which is possible
even in grass5.0. Otherwise we will maintain two similar libraries for vector
and sites. New vector library and modules will support points. I was not
courageous enough to suggest such thing like replace site_lists by vector
files. I remember some mails here that this question was deeply discussed
and ascii format was found as good solution but I
think that for g51 we could consider site_lists format once more. What are
the argumets for points separated from lines and areas if any?
Radim
Regards
Andrea Aime
attribute support and DBMS integration..
I think it would be desirable if that data-base support also associates
drawing attributes with the vector objects; e.g. area color fill and
pattern, line weights, line styles, line color, point symbol, size and
color. No doubt there are more. Presentation is one of the most
important functions of GIS. GRASS' current state of division between
analysis and presentation will make further improvements difficult.
Regarding the separation of vector data and site data...
Sites should function as a tie between a map location and a database.
The current support for sites is a conceptual start in that direction,
but of little practical use. For instance, one of my clients has
somewhere over a 100 sites (wells) with a few to 100's of pages of data
that is uniquely associated with each site. That is by no means a large
example. I would like to be able to use a site list-like feature to
organize and access that data.
If your concept of data base support for vectors can be extended that
far, then by all means merge site lists with vectors. It will make
things much simpler. Otherwise, I think it is far better to keep sites
for separate development.
Roger Miller
Lee Wilson and Associates
Roger
Though this is broadly to be welcomed, a number of alarm bells are
ringing here. One of the problems with entry-level GIS, which echoes a
problem across the whole spectrum of desktop philosophy and culture, is
the problem of over-integration of logically distinct functions.
Presentation is very important, and no-one will deny GRASS has much
(everything!) to still do here, but it _is_ something essentially
different from analysis, and digitising - which is really a CAD-like
function - is something different again, tho' the latter is related to
data structure and storage. I include such functions as cut and patch as
`digitising'. Analysis needs to deal with attributes and it needs to be
spatially aware, but doesn't mostly need to edit - if need be it can
call the editing layer.
It is good to keep the processes the user doesn't need (or want) to see
in the background, but it is also important to make sure the engine
processes each stage the best way, logically, it can and not compromise
the whole by confounding the parts. It's always _easier_ to cut corners
but I think we can achieve what you suggest as long as we keep in mind
what we are aiming for is to maintain GRASS as a `high-end' system.
In the version 5.1 dig file, there are now separate entity types for
point data. There is a `site' record and a `centroid' record, which are
both point types. Actually both are new: the old way of registering a
point is as a line of two identical points, and the location of the
degenerate nodes is the site location. Area point features are stored
currently in dig_att. In GRASS 5.0 however mostly sites use the
text-based sites API.
This suggests moving on to the possibility of linking up to heavy duty
RDBMS engines where more than a few small attributes or complex linking
is required. So plugins to PostgreSQL/Oracle/etc. or ODBC need to be
developed to handle this. But surely this is overkill for the attribute
data requirements of most maps, so for day-to-day needs, a simple
vanilla DBMS system should do.
The sites API will probably go the way of many redundant features in
GRASS. It will be dropped when the vector engine takes over its
functions.
David
Roger Miller
Andrea, etc,
I think your email on GRASS 5.1 attribute support is excellent. A few points
from my own thoughts:
o My thoughts on OSVecDB remain focused on what OGC calls simple
   features. In particular, this is a non-topological approach, and it
   seems that the GRASS community does not wish to alter the approach to
   vectors this dramatically. Thus, I think OSVecDB will not be the core
   methodology for storing GRASS vector data unless it is extended to
   support topology.
o There are some very liteweight approaches to providing SQL support. If
   you think it would be desirable for even a "base" GRASS system to have
   SQL support this might be accomplished by using something like SQLite
   which provides a high degree of SQL support bug storing data in GDBM
   files. Folks willing to install a real database could replace SQLite
   with PostgreSQL or something similar.
   SQLite is at http://www.hwaci.com/sw/sqlite/ and I have been quite
   impressed with it from my modest involvement.
o DBase files would be sufficient if you aren't concerned about having
   SQL support as a core service. However, in this case I would look
   around for a better DBF library that includes support for attributes.
   My DBF support in Shapelib is just adequate for it's purposes.
Roger also writes that that he feels that presentation information should
be stored in close association with vectors, like the attributes. I agree
to some extent, but I think caution should be employed. Presentation is
something that can grow arbitrarily complicated and this contributes
substantially to the complexity and interchange difficulties of CAD formats
like DXF and DGN.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | Geospatial Programmer for Rent
into a vector GIS:
parcel, and so on);
Some thoughts.
A) Multi-att support is largely underway in GRASS5.1. The question of
displaying the data and querying through a graphical interface is a
separate question. There is an idea to have a geometric representation
of the map generated on the fly and stored in memory while a map is
being displayed and queried. Also, this could be cached so that an
unchanged, recently accessed map can be quickly redrawn without having
to re-render the data from the topo data (in dig and dig_plus). This
would be optional and the user would determine how much disk space to
allocate to the cache.
Getting a decent (screen) display in the first case isn't something
we've really addressed yet. Development on the GRASS monitor will
continue for now, but maybe we should be thinking about a new GUI(
GTK+/KDE-based, Java, win32, openstep) or perhaps drivers for existing
3rd-party systems to access, display, query, maybe even edit GRASS
databases. This is for beyond 5.1
B) I think this requires a wholly new approach to get such operations
working correctly and efficiently. Segmented processing of vector maps
and network capabilities are needed here. This is closely related to the
question of improving the build process, so that it can allow updating
of maps without having to do monolithic builds each time. It also seems
to me to be very dependent on C). . .
dig_plus stores topo data, but not spatial locational data, at least not
in a form that would allow efficient and spatially confined querying. So
the plan is to have a third representation of the map, which would be
essentially an R-tree (or similar) whose data is the type and index of
the entities in the map, and is keyed spatially. A new element of the
GRASS database would be created to store this - dig_spatial or something
similar. For this we need to establish some kind of generic spatial tree
with an API that allows easy access.
  DBMS);
I agree we should move away from text file representations as they are
too slow - except maybe for single-stage operations like import and
export.
As in my remarks above. . . but it might be possible (through server
side programming perhaps) to allow the tables to access the dig_spatial
file. This has been mentioned on the list before, at least for
PostgreSQL.
An example:- a table could contain a field that has information about
the size and offset of a data block in dig_spatial containing the
necessary data. Then a query could look up some records by index or
querying on another field, extract this information, perform a spatial
query on the R-tree (with its internal API), and then return the entity.
This may then be part of another map. Or - a direct spatial query could
look up the R-tree and return the records which are then queried with
SQL, returning a result. And of course it is all behind the scenes',
giving the appearance of integrated spatial and data querying.
  too flexible);
Currently (in 5.0) :
Point data are stored as lines of two points with the same start and end
point. Weird! In 5.1 we have two point types - a SITE and a CENTROID.
This is in the vector map, not the site lists.
Lines, really polylines, are the atomic units of most GRASS maps, linear
and area. Two types exist in 5.0 and will be the same (essentially) in
5.1: LINE and BOUNDARY. These represent the arc segments of the networks
or two-dimensional manifolds that make up GRASS vector maps. LINE maps
should conform to the definition of a NETWORK, and area maps (with
polygons) to a 2-dimensional manifold (2DM). I think this is how it is
just now, but we should make sure it is followed strictly.
Areas or polygons are a kind of composite entity, as are islands, which
are composed during the build process from indexed references to their
sub-components. I think one of the short-comings of the topological
format at the moment is that it allows only these derivative types,
while I think many others would be useful eg. - as a minimum - linear
aggregates, to allow entities that reference branched structures as a
single unit, like tributary systems. This would be _in addition to_ not
instead of, providing categories for the individual arcs. Multipoint
sets are also required, eg. a set of relevee locations may constitute a
vegetation community description, where the individual sites might have
their own quite distinct set of attributes. It works the other way
round: why can't area boundaries have their own attribute sets separate
from those of the area itself? There is occasionally a need for this,
though it's rarer than the other examples above.
site API.
The hierarchy of entities in the dig_plus structure are a good candidate
for OOP treatment, and polymorphism through inheritance. That would
reduce code, but not necessarily binary size. It would also make a more
versatile and manageable data structure: but we don't it seems do that!
Regards
David
Regards
Andrea Aime
My concern is that *if* there is any intent to improve the presentation
capabilities available in GRASS then it will ultimately be necessary to
provide database capabilities to serve drawing attributes. Those
capabilities can be built as an inherent part of the vector attributes
database. Alternatively the database capabilties can be added later in
a separate, parallel and mostly duplicative effort. The latter
alternative makes little sense to me.
I think there's a substantial need in GRASS for integration of map
preparation, map analysis and map presentation. Certainly it would be
possible to go too far in that direction, but right now we are so far
from that extreme that worrying about it seems a little premature. If
my own setting is an indicator then public use of GRASS will be limited
until the time that GRASS offers more evenly balanced and integrated
capabilities.
I appreciate that goal, but as it is now GRASS seems to be intended more
as a `back-end' system, than as a `high-end' system.
I think David is right that it would be overkill for day-to-day needs,
so long as those needs are limited to the needs for map analysis, and
probably for map presentation. The data needs for map construction are
much greater than the needs for analysis or presentation and a database
system designed to give the capabilites needed for map analysis is
likely to be woefully inadequate to serve the demands of map
construction.
GRASS currently offers some Postgres support, and certainly that is
helpful for map construction, but it doesn't come close to meeting the
needs.
Roger Miller
On Sun, May 13, 2001 at 11:06:58PM -0600, Roger S. Miller wrote:
[snip]
capabilities.
[snip]
construction.
needs.
I think we all can agree GRASS has a ways to go on both attribute data
support *and* presentation. Now, if for a vector "map", if each
layer/component (SITE, LABEL, LINE, AREA) has a separate attribute table
then wouldn't it be a simple matter to *allow* the user to define one
column of the table to indicate a "style" for the given thing. Then
presentation routines could be told which field to use for looking up
the drawing style for the given thing. The styles themselves, could
consist of simple text files defining some appropriate variables. GRASS
would provide a "DEFAULT" style as well as several "sample" styles.
Styles could be indexed by name or number and would reside outside of
the database proper (e.g. in etc/styles/ and possibly
/home/user/.grass5/styles/).
Hypothetical polygon style example:
[myStyle]
AREA {
  line-color: #000000;
  line-width: 0.4pt;
  fill-style: stipple;
  fill-pattern: hatchure10;
  fill-foreground: #0000FF;
  fill-background: transparent;
The details would have to be fleshed out. If a style could not be
rendered or found, the drawing agent should try to render what it can
(possibly using the default settings).
Being able to define display styles that aren't tied to a particular map
makes it easier to apply them to subset maps or related maps and get
consistent results while only having to define the style once. Also, I
think such a thing doesn't unduly burden any analysis/management aspects
of the system.
Comments?
Eric G. Miller <egm2@jps.net>
[snip]
> capabilities.
[snip]
> construction.
> needs.
[myStyle]
AREA {
        line-width: 0.4pt;
of the system.
Comments?
Has anyone had a look at the draft ISO standards? They deal with a lot of these
issues. Been talking to our local rep on the TC/211 geomatics committee, and the
impression I get is that they are not averse to open source apps implementing the
standards :wink: More on this if anyone interested.
cheers,
John
john reid e-mail john_reid@uow.edu.au
technical officer room G02, building 41
school of geosciences phone +61 02 4221 3963
university of wollongong fax +61 02 4221 4250
uproot your questions from their ground and the dangling roots will be
seen. more questions!
                                                       -mentat zensufi
apply standard disclaimers as desired...
lot of these issues. Been talking to our local rep on the TC/211
geomatics committee, and the impression I get is that they are not
averse to open source apps implementing the standards :wink: More on
Standards for what?
Frank Warmerdam wrote:
Andrea, etc,
[snip]
Wow, is seems really impressive. A good SQL support and index in only
9000
lines of code... Radim, how it compares to g51 dbf driver? Should we
take
a more closer look at it? It seems that SELECT support is quite
complete,
and indexing capabilities are interesting for querying large data.
Import/export
to and from PostgreSQL is another interesting plus...
Regards
Andrea Aime
Sorry, I look at it some time ago and I didn't noticed it had been
updated. I'll print it, have a look at some more discussion and then
talk back when I have something new to say :slight_smile:
Regards
Andrea Aime
PS: I'm interested both in spatial indexes both in overlay operations...
can I join your work :-)?
Standards for what?
ISO Geographic Information/Geomatics 19100 series
http://www.statkart.no/isotc211/
                                                       -mentat zensufi
9000
take
complete,
Import/export
Regards
Andrea Aime
SQLite seems to be a good solution. The only problem I see is that there is no
GUI front-end which was one of my criteria. Dbf files may be edited in StarOffice
and MSAccess (including forms). I thing that we don't have human resources for developing
database front-end within grass and we don't want to reinvent wheel. So if such front-end
is available is important.
BTW: SQLLite files are not portable (The key size thus depends on the size of
an integer on the host computer.) but that doesn't matter.
I think that both dbf and SQLite have some advantages. I don't think
we can find the 'best' system and that is the reason why I prefer optional drivers
for various databases. I don't see any problem in using new sqlite driver
beside odbc, dbf and others.
Everybody is welcome. David is working on spatial related tasks.
I thing that you could start work on spatial operation (overlay) functions.
We have only dig_point_in_area() in g50 and we need ALL spatial operations
between ALL element types. Have you any ideas?
Radim
Radim,
  I've been looking at the spatial operations subject. I've
found at least one polygon algorithm that should handle all of the set
operations (intersect, union, etc..). I'm working towards fully
understanding how to implement it. I've also been looking at some of
the others like clipping lines with polygons (possibly resulting in
multiple lines). With a little more study I think I'll be ready to
start implementing these things.
> 9000
> take
> complete,
> Import/export
> Regards
> Andrea Aime
Well, my concern was SQL related: IMHO the command should be the same
even
if the user adopts different DBMS, I don't like much the idea of a
special command
for postgres, another for dbf, another for ODBC and so on. Do we pass
the query
to the driver and let hid decide if it is able to manage it or not?
Well, my first task would be to get a v.overlay command working. I
already found
a GPL'd C library that performs polygon to polygon overlay (PolyBoolean,
old version,
the new version is C++ based, non GPL and uses only integer coordinates)
it should
be easy to adapt it to GRASS. But it doesn't work for polygon/line
overlays, so
it has to be extended. Moreover, there must be a fast way to locate
polygon that
can intersect (an R-tree or something like this). The sama applies to
dig_point_in_area:
useful, but slow since you have to compare each point with each polygon.
Some
kind of indexing is required altogheter...
Regards
Andrea Aime
even
special command
the query
That is how d.vect (g51) works now. One command may be used with dbf or odbc.
Modules know nothing about driver except its name. Whole comunication is
done by DBMI library.
already found
old version,
it should
overlays, so
polygon that
dig_point_in_area:
Some
Regards
Andrea Aime
Radim,
OK, I'll leave spatial operations for you.
Should be spatial operations part of vector lib ( Vect_*() ) or shall
we open new vector spatial lib (VS_*()) - maybe GPL only (not LGPL).
We could maybe start with definition of functions we want?:
int VS_analyse( struct Map_info map1, struct Map_info map2,
     int element1 , int element2, int operator, double distance)???
operator: WITHIN, CONTAIN, OVERLAP, ... and many others (probably take names
              from some standard - openGis???)
and so on.
Radim
Radim,
It seems to me that if we use easily substitutable SQL based RDBMS systems
then folks that need forms support and a GUI front end can choose an
RDBMS that has them. If we use DBF and depend on external gui front ends it
still won't be possible to distribute GRASS database forms applications since
different users might choose different target RDBMSes, right?
Is the GUI front end and forms requirement just so that users can see their
data interactively, or so that substantial forms based applications can be
built?
Someone mentioned the issue of having different programs for different
databases. I completely agree that if we integrate SQL support smoothly
into GRASS that the applications should be insulated from the actual database
backend by some sort of plugable library. This might be based on an existing
standard like ODBC or just a custom simplied database API. I was impressed
with the relative simplicity of the abstracted database interface in Python.
BTW, does Postgres have a nice gui front end? I have always done my work from
psql, but I would dearly love to try something a little more visual. :slight_smile:
This is annoying. In the short term I guess it would be necessary to do a
database dump and reload to transport to different system types. I would
ideally like to see some sort of automatic translation be done at lower
performance at some point.
Best regards,
Radim,
built?
Depending on your client you can choose among:
* pgAccess, tcl/tk interface for Unix desktop;
* pgAdmin, Visual Basic interface for Windows users;
* phpPgAdmin (or something like this...), a web interface
.. need more?
Uhm, I don't see it as a major problem, v.out.ascii can dump the table
along with the coordinates, and v.in.ascii do the opposite.
Regards
Andrea Aime
> is no GUI front-end which was one of my criteria. Dbf files may be edited
> in StarOffice and MSAccess (including forms). I thing that we don't have
> human resources for developing database front-end within grass and we
> don't want to reinvent wheel. So if such front-end is available is
> important.
Radim,
it still won't be possible to distribute GRASS database forms applications
since different users might choose different target RDBMSes, right?
At this stage of grass development I think this is the only way, i.e.:
grass (with minimal functionality for accessing attributes) + external GUI
front-end for RDBMS.
built?
Some simple forms for viewing data interactively must be part of grass
(such simple tcl/tk form for db sites editing is already db.attr accesible by
db.what in g50) but for real applications we must use some third party
solution (library is not enough, visual designer is needed) I think.
database backend by some sort of plugable library. This might be based on
an existing standard like ODBC or just a custom simplied database API. I
was impressed with the relative simplicity of the abstracted database
from psql, but I would dearly love to try something a little more visual.
:slight_smile:
> size of an integer on the host computer.) but that doesn't matter.
Yes, but dump (vector export, import) will be needed anyway because of
different user RDBMSes.
Radim
Best regards,
