A colleague has imported a dxf map of many polygons. It seems as if the dxf import driver imports these as vector lines or area boundaries only. Is there a way to transform many closed boundaries to areas without going into v.digit and assigning a centerpoint and label to each boundary individually?
Michael Barton
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Michael,
Try this:
v.type input=old_map_name output=new_map_name type=boundary,area
to change the type from boundary to area,
C.
Christopher J. Fonnesbeck ( c h r i s @ f o n n e s b e c k . o r g )
Georgia Cooperative Fish & Wildlife Research Unit, University of Georgia
Michael,
Try this:
or in GRASS version <5.7, v.line2area might work. (I have used it with
some success on v.in.dxf input before). But as Christopher said you
might get further by converting the map into 5.7 vector format and using
some of the new tools there.
Paul
