[GRASS5] Multiple sessions
Are there any objections to enable multiple sessions
(one per mapset) in 5.7? Basically:
cp $HOME/.grassrc57 /tmp/grass57-$USER/gisrc.$$
set GISDBASE, LOCATION_NAME, MAPSET
check $LOCATION/.gislock
run GRASS session
rm -f $LOCATION/.gislock
cp /tmp/grass57-$USER/gisrc.$$ $HOME/.grassrc57
rm -f /tmp/grass57-$USER/gisrc.$$
Suggested patch is attached.
Radim
(attachments)
init.sh.patch (2.32 KB)
run GRASS session
There is one set of monitors per user, but monitors are tied to the
session in which they are started due to the redraw-on-resize code
(any commands will be run with $GISRC set to the value which the
driver inherited from mon.start).
I think that we would really need to have one set of monitors per
session. Either that, or just remove the redraw-on-resize code (which
would be a good thing in any case).
> run GRASS session
So, change _get_make_sock_path() (lib/gis/unix_socks.c) to return
/tmp/grass'VERSION_MAJOR''VERSION_MINOR'-$USER-$GIS_LOCK
instead of
set $GISRC to tmp/grass57-$USER-$GIS_LOCK/gisrc
and close all running monitors when GRASS session is closed.
Patches attached.
Radim
(attachments)
unix_socks.c.patch (1.32 KB)
init.sh.patch2 (2.78 KB)
