On Sat, Nov 23, 2002 at 06:09:20PM +0000, Glynn Clements wrote:
Markus Neteler wrote:
> > > > written and uploaded at the CVS are two new DBMI drivers,
> > > > one for PostgreSQL and one for MySQL. To compile them one needs grass51
> > > > and 'libpq' or 'libmysqlclient', respectively.
> > > > The code is at grass51/db/drivers catalog.
> > > Glynn, may I ask you to add a test to 'configure[.in]' for the mysql
> > > libs and include directories?
> > What should it be testing for?
> > What is the header called, what is the library called, which other
> > libraries (or sets of libraries) might be required, and which function
> > should configure expect to find in that library?
> According to
> grass51/db/drivers/mysql/Makefile
> and
> grass51/db/drivers/mysql/globals.h
> it needs
> -L/usr/local/lib/mysql
> -lmysqlclient
> and
> #include <mysql/mysql.h>
That's 2 out of 4; I still need to know a symbol which will be present
in libmysqlclient, and which libraries libmysqlclient might depend
upon.
I'll take a guess at mysql_query() being defined in libmysqlclient (it
is referenced in db/drivers/mysql, but doesn't appear to be defined
anywhere), and I'll assume that no other libraries need to be
specified.
Probably Alex can help. I just tried it:
checking for mysql_query in -lmysqlclient... no
configure: error: *** Unable to locate MySQL library.
thuille:grass51[273.17] locate libmysqlclient
/usr/lib/mysql/libmysqlclient.so.10
/usr/lib/mysql/libmysqlclient.so.10.0.0
/usr/lib/mysql/libmysqlclient.a
/usr/lib/mysql/libmysqlclient.so.9
/usr/lib/mysql/libmysqlclient.so.9.0.0
thuille:grass51[274.18] nm /usr/lib/mysql/libmysqlclient.so | grep
mysql_query
0000a210 T mysql_query
cat config.log
configure:9326: checking whether to use MySQL
configure:9346: checking for location of MySQL includes
configure:9372: checking for mysql/mysql.h
configure:9380: gcc -E conftest.c >/dev/null 2>conftest.out
configure:9418: checking for location of MySQL library
configure:9443: checking for mysql_query in -lmysqlclient
configure:9460: gcc -o conftest -g -O2 conftest.c -lmysqlclient 1>&5
/usr/bin/ld: cannot find -lmysqlclient
collect2: ld returned 1 exit status
configure: failed program was:
#line 9449 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char mysql_query();
int main() {
mysql_query()
; return 0; }
Probably the library is not found?
