We can not determine full path to install GRASS with new configure.
${prefix}/grass5 is the default, however how can i change this to
/usr/local/grass or etc?
And another problem:
I could set ${prefix}=/usr/local/grass and ${bindir}=/usr/local/grass/bin
with old configure.
However, i have no clue about ${prefix}/??? with new configure, just trial
and error? I could not know ${prefix}/grass5 was used until first trial.
At the second time configuring, I could set ${bindir}=/usr/local/grass5/bin.
I think old configure would be better for flexible and easy setting.
Huidae Cho
subject 'unsubscribe grass5'
On Thu, Dec 07, 2000 at 12:49:30AM +0900, GRASS wrote:
Hi developers,
You can't at the moment. The GISBASE is kinda hardcoded to this in
configure (you could probably hack the configure script directly if you
wanted, search for NAME_VER and you'll find the spot to change).
with old configure.
This is related. --bindir= should work still to set some other path for
the start-up script.
Just regards these recent changes, or overall?
Eric G. Miller <egm2@jps.net>
instead of answering individual question, I propose you
try the current CVS version. I have reverted partly.
I have seen that it was hardcoded and changed the related
files:
What you can do now:
configure (with or without autoconf)
-> Installs into /usr/local/grass5
configure --prefix=/opt
-> Installs into /opt/grass5
Hope that's o.k. for beta9. I definitly want to get it out NOW.
Of course I listen to your comments first
Yours
O.k., no comments received. So I start tagging now.
Please don't check in for some minutes from now.
I'll post another mail if finished.
Thanks
