- documentation cosmetics -
I have extended:
lib/gis/parser.c
include/Make/Html.make (separated from Rules.html)
tools/build_html_index.sh
to generate an additional HTML header line to include a simple
CSS style file. Basically the examples can be coded now
like this in the 'description.html' files:
<div class="code"><pre>
v.to.db -p roads option=length type=line units=k
</pre></div>
Such an example appears indented with type write font in a grey box
which makes it easier to distinguish in the text flow.
And: Section titles are green colored now (such as the GRASS Web site).
Example:
vector/v.to.db/description.html
TODO 1:
Now all the tons of examples should be homogenized and changed to
above style.
TODO 2: Fix tools/g.html2man/g.html2man to accept multiple lines
in above environment (two or more lines of example in a single
</pre></div>
At time the line break is eaten and not preserved (hi Daniel, maybe
you could help?). Maybe these examples could be indented a bit in the
MAN pages?
By tomorrow morning Italian time the updated man pages will be online.
That's a great move. Do you think it makes sense to use another <div> for output?
Someting else: since this needs to be done for every description.html, it
might be good to revise the examples and make them all work with spearfish.
What do we gain? It's a very good starting point for building a (minimal) set
of regression tests. I'm positive that is something to do for 7.0.
I'm revising g.html2man to take care of line breaks within PRE. Should land on
CVS today.
Daniel.
-- Daniel Calvelo Aros
---------- Original Message -----------
To: grass developers list <grass5@grass.itc.it>
Sent: Fri, 4 Nov 2005 17:21:41 +0100
Subject: [GRASS5] New CSS based doc style for GRASS usage examples
I have extended:
lib/gis/parser.c
</pre></div>
site).
Example:
TODO 1:
above style.
</pre></div>
MAN pages?
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
------- End of Original Message -------
Well, maybe (no idea).
Yes, fully agreed (and I tried as much is possible for examples written
by me).
CVS today.
Nice, thanks!
