[GRASS5] New dig 5.0 format with categories and z-coordinate
Proposal for new dig 5.0 format with categories and z-coordinate.
General:
Each element may have none, 1 or more categories (cats).
More cats are distinguished by category numbers (cat_num).
Only one cat with cat_num=1 will be used at this stage
and multi-category support on modules level will be added in
future.
Z-coordinate will be optional and both 2d and 3d files may
be written.
Implementation steps:
1. Define new dig format:
    like 4.x but in:
    - head : Add type field for 2d/3d
    - body : - between element type and number of coordinates is inserted:
                 - number of categories 0-255 (1 byte)
                 - category number(s) 1-65535 (n_cats * 2 bytes)
                 - category(s) 1-4294967295 (n_cats * 4 bytes)
             - for 3d files z coordinate is written in the same style as x,y
2. Define new structures and write functions:
    #define CENTROID 0x08
    #define FILE_CENTROID 3
    typedef unsigned char VCNCATS;
    typedef unsigned short VCCATNUM;
    typedef unsigned int VCCAT;
    struct line_cats {
       VCNCATS n_cats; /* number of vector categories on one element */
       int alloc_cats; /* size of allocated space */
       VCCATNUM *cat_num; /* pointer to field of category numbers */
       VCCAT *cat; /* pointer to field of categories */
    struct line_pnts {
       double *x;
       double *y;
       double *z; /* null for 2d */
       int n_points;
       int alloc_points;
    struct line_cats *Vect__new_cats_struct (void);
    int Vect_append_cat ( struct line_cats *, VCCATNUM, VCCAT);
    int Vect_read_next_cats_line ( struct Map_info *, struct line_cats *,struct line_pnts *);
    long Vect_write_cats_line ( struct Map_info *, int type, struct line_cats *, struct ine_pnts );
          ( for backward compatibility this function duplicates cats to dig_att file
           so that old modules can work with new dig files )
    Vect_read_next_line( ) - rewrite to read both 4.x and 5.0 2d/3d
         and of course all functions called by these and some others.
3. Rewrite v.build to support both dig 4.0 and 5.0.
   Write v.dig module for conversion from built dig_plus to dig5.0.
4. Request for testing on other platforms. Result of v.dig and v.support
   should be the same as original dig_plus and all modules should work
   with dig in 5.0 correctly.
5. Rewrite all modules which read from dig_plus (level2) or from
   other sources (v.in.*) to new dig format.
6. Rewrite remaining modules which read from dig file. Here is the problem
   because if module writes dig5.0, it must also read in dig5.0 format and
   so imput file must be converted by v.support and v.dig first.
David D Gray, Radim Blazek
subject 'unsubscribe grass5'
I have extended the number of accepted files in r.patch from
10 to 50. Hope this is o.k.
Then I want to add a new flag:
-z Use zero (0) for transparency instead of NULL
I feel this is useful if you have common maps and want to
avoid extra work due to NULL assignment.
This flag is implemented more or less (currently commented
in Gpatch.c), but the zero (0) check is missing. I am not
shure how to implement this check properly (file do_patch.c).
If somebody could assist here ... :slight_smile: The updates are in CVS.
Thanks in advance
Dear Radim and David,
many thanks for the long awaited proposal! I am shure that an
updated vector format would increase the acceptance of GRASS.
If you allow, a question concerning the Z-coordinate support:
Do you think of tilted vectors (maybe 2.5D vectors) or even
of full 3D vectors to construct geometric volumes like houses
or whatever? The latter would require a format which allows to
stack vectors and have vertical vectors etc.
Please don't feel bothered of my question, I just want to
understand your proposal.
Yours
General:
future.
be written.
    like 4.x but in:
    struct line_cats {
    struct line_pnts {
       double *x;
       double *y;
       int n_points;
       int alloc_points;
The core format is a true 3d format as there is no assymetry between the
x- and y- coords and the new z-coord. But most modules work on the
presumption of a projected 2d space, so in the first instance most
immediate applications will be to work with projection+elevation eg. a
projected TIN model. Also it will now be easier to work directly from
vector data to obtain true point to point values such as slopes, aspect
etc (instead of having to interpolate from raster or sites data).
Then, though this would be extra to our immediate plans, a volume
handling capability could be added by creating combinations of AREA into
SURFACE and SURFACE into VOLUME (we'd also need an EDGE). Then modules
to deal with g3d <-> v3d just as we do with the 2d stuff at present. We
could probably just hack this in to the existing system, mostly to
v.build and the display/edit modules, but I don't think much else, apart
from the new modules.
`CAD' type support would require 1) layers 2) a format, maybe a vector
graphics format 3) some kind of support for composite maps (this would
be a good idea generally-does anyone know if it has ever been
discussed?) where a combination of vector/raster/CAD etc layers could be
treated as one map.
So that is a bigger job. Maybe we could complete the immediate task, and
possibly create volume support through the course of development of
GRASS 5.x. However to go much further, do we want to continue hacking
more stuff on to GRASS3 dig and GRASS4 Vect, or is it time to think
about a rewrite of the vector engine? There is a spec for a vector
engine dating back some years, that was originally intended for
`GRASS6', in the documents directory, though it appears the code base no
longer exists (?).
David
