[GRASS5] New GIS & GRASS5 user with many questions...
GRASS5 is compiled, and appears to run, but are there any sample data sets I can use to test and familiarize myself with GRASS5?
********** Output from testgrass.sh **********
org:/install/grass5.0.0pre3 # ./testgrass.sh
testing in UTM projection environment:
projection: 1 (UTM)
zone: 13
datum: ** unknown (default: WGS84) **
ellipsoid: ** unknown (default: WGS84) **
north: 4928000
south: 4914000
west: 590000
east: 609000
nsres: 50
ewres: 50
rows: 280
cols: 380
Test the -129 r.mapcalc bug:
EXECUTING testmap = ... 100%
CREATING SUPPORT FILES FOR testmap
range: -129 -129
r.mapcalc bug test o.k.
Tests finished.
My goal is to display county level data sets, currently in FIPS codes, onto a map of the US, and individual states. I'd like to deliver the images via webserver to clients using a browser. As I perused the programming manual, I noticed that there are limitations to html's ability to render clickable points, which I can work through later, but I'd like to know if I'm on the right track in using GIS & GRASS5. Also, any links, hints or info anyone can provide to additional information would be greatly appreciated.
Thanks!
Hi Samizdatt,
the ./testgrass.sh is only intented to test GRASS on a system level.
You may want to use
Spearfish sample data,
have a look at:
http://grass.itc.it/data.html
GRASS 5.x: SPEARFISH dataset (9.6MB size)
+ " SPEARFISH dataset related documents: "
Enjoy,
Markus Neteler
projection: 1 (UTM)
zone: 13
north: 4928000
south: 4914000
west: 590000
east: 609000
nsres: 50
ewres: 50
rows: 280
cols: 380
range: -129 -129
Tests finished.
Thanks!
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Thanks Markus!
The adventure begins...
Markus Neteler wrote:
Hi Samizdatt,
You may want to use
have a look at:
Enjoy,
Markus Neteler
> projection: 1 (UTM)
> zone: 13
> north: 4928000
> south: 4914000
> west: 590000
> east: 609000
> nsres: 50
> ewres: 50
> rows: 280
> cols: 380
> range: -129 -129
> Tests finished.
> Thanks!
> grass5 mailing list
> grass5@grass.itc.it
grass5 mailing list
grass5@grass.itc.it
