and I still thought that the 6.1 is a beta and you are talking about a 6.2? I think what the most important thing is which has to be improved for a beginner is the installation of grass. I'm running on cygwin and I did not dare to try anything else which is provided by the cygwin installer (at least that there is some version at all is a great help).
You are right, as a new user I had problems to understand what a location/mapset is and how to create them. What me helped was a step by step tutorial (sorry I'm only civil engineer who uses Grass for private purposes).
I'm sometimes still confused that some commands need instead of "input" a "map" at least this should be aliased.
An other thing I realized quite late is that many options are only working when Grass is compiled with the right commands, but when you have installed a binary version you hardly figure out which "plugins" are working (mrsid in, ecw out, ...)
But I'm not thinking bad of Grass at all! I only takes a lot of effort to get into it. Now I can handle some functionality like importing maps, reprojecting maps, joining maps, using r.resamp and also exporting them quite well. For getting so far having a step by step manual helped a lot (and also the mailing list).
A final remark on the EPSG list. It seems that no all possibilities (grids) are included and that (at least one) lacks the right false northing. Also (when I under stand right) EPSG codes are available for Datums and national meter grids (which need a datum).
If you need a beta tester who can "simulate" a new user, then you can always ask me
Wolfgang
Michael Barton schrieb:
With the move toward releasing GRASS 6.2, it’s time we had a new intro to greet users starting GRASS.
I’d hoped to make something really spiffy, easy for first time users to navigate without getting confused about GRASS jargon, but still quick for experienced users. Alas, I haven’t had the time to do all this before the impending 6.2 feature freeze, but I did manage to update things somewhat from the venerable, Spartan grey intro.
I’ve rearranged the items on the intro screen to distinguish different functions, changed the descriptions to make it clearer that locations are for projections and mapsets are where a ‘GIS’ is stored, etc. I also added a new button to create a projection location from a georeferenced file (uses GDAL/OGR via g.proj). Finally, I added some color to the intro. No I didn’t make it green, but I did add a nice GRASS graphic.
Many thanks to Markus who helped me get this committed to the cvs, where it now resides for your geospatial enjoyment.
I think the next step would be to replace the g.setproj terminal screen for defining projections with a nicer GUI one based on g.proj. Another thing would be to add a search function to the excellent EPSG codes database.
Michael
School of Human Evolution & Social Change Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
