Hamish,
On Mon, Jan 24, 2005 at 08:14:39PM +1300, Hamish wrote:
idea: use xmessage (should be installed on all Mac+Cygwin with X?)
if GUI:
if $TERM is csh like
setenv GRASS_PAGER "xmessage -center -file -"if $TERM is bash like
export GRASS_PAGER="xmessage -center -file -"
I tried this idea, works well for g.list etc.
However, it doesn't with g.setproj:
GRASS 6.0.cvs:~ > g.setproj
WARNING! A projection file already exists for this location
(Filename '/ssi0/ssi/neteler/grassdata/srilanka/PERMANENT/PROJ_INFO')
Please specify projection name
Enter 'list' for the list of available projections
Hit RETURN to cancel request
list
usage: xmessage [-options] [message ...]
where options include:
-file filename file to read message from, "-" for stdin
-buttons string comma-separated list of label:exitcode
The code in lib/gis/get_projname.c is
do {
fprintf(stderr,_("\n\nPlease specify projection name\n"));
fprintf(stderr,_("Enter 'list' for the list of available projections\n"));
fprintf (stderr, _("Hit RETURN to cancel request\n"));
fprintf(stderr,">");
} while(!G_gets(answer));
G_strip(answer);
if(strlen(answer)==0) return -1;
if (strcmp(answer,"list") == 0) {
if (isatty(1)) {
sprintf(buff,"$GRASS_PAGER %s",Tmp_file);
else
sprintf(buff,"cat %s",Tmp_file);
system(buff);
Is it the isatty?
