On Tue, Feb 01, 2005 at 11:45:19AM -0500, John Gillette wrote:
xmessage -center -file - any_file.txt
at a terminal reproduces your error message.
Do you need the final dash (-) in the GRASS_PAGER variable?
In other words:
setenv GRASS_PAGER "xmessage -center -file"
Magic! This works
if $TERM is csh like
if $TERM is bash like
export GRASS_PAGER="xmessage -center -file"
Thanks, John!
This should be documented somewhere in the online
help system.
> -----Original Message-----
> From: grass5-admin@grass.itc.it [mailto:grass5-admin@grass.itc.it]On
> Behalf Of Markus Neteler
> Sent: Monday, January 31, 2005 6:11 AM
> To: Hamish
> Cc: grass5 developers list
> Subject: Re: [GRASS5] New help button - please text review
> Hamish,
> On Mon, Jan 24, 2005 at 08:14:39PM +1300, Hamish wrote:
> > idea: use xmessage (should be installed on all Mac+Cygwin with X?)
> > if GUI:
> > setenv GRASS_PAGER "xmessage -center -file -"
> > export GRASS_PAGER="xmessage -center -file -"
> I tried this idea, works well for g.list etc.
> However, it doesn't with g.setproj:
> GRASS 6.0.cvs:~ > g.setproj
> WARNING! A projection file already exists for this location
> (Filename '/ssi0/ssi/neteler/grassdata/srilanka/PERMANENT/PROJ_INFO')
> Please specify projection name
> Enter 'list' for the list of available projections
> Hit RETURN to cancel request
> >list
> usage: xmessage [-options] [message ...]
> where options include:
> -file filename file to read message from,
> "-" for stdin
> -buttons string comma-separated list of label:exitcode
> The code in lib/gis/get_projname.c is
> do {
> fprintf(stderr,_("\n\nPlease specify projection
> name\n"));
> fprintf(stderr,_("Enter 'list' for the list of
> available projections\n"));
> fprintf (stderr, _("Hit RETURN to cancel request\n"));
> fprintf(stderr,">");
> } while(!G_gets(answer));
> G_strip(answer);
> if(strlen(answer)==0) return -1;
> if (strcmp(answer,"list") == 0) {
> if (isatty(1)) {
> sprintf(buff,"$GRASS_PAGER %s",Tmp_file);
> else
> sprintf(buff,"cat %s",Tmp_file);
> system(buff);
> Is it the isatty?
> Markus
> grass5 mailing list
> grass5@grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
> In other words:
Magic! This works
Thanks, John!
help system.
... ah yes. The "-file -" indicates input is to be piped from stdin.
xmessage works, but is very inconsistent with the rest of the GRASS GUI.
One problem I saw with xmessage is that it didn't give horiz. scroll
bars and when you did g.list for example, the right hand column of maps
could be silently hidden unless you thought to resize the window.
I like the g.message tcltk solution better. The attached prototype needs
a box with horiz and vert scroll bars (ala d.what.vect) for the longer
lists and more robust piping from stdin..
or just send to the existing lib/form/html_library_grass.tcl ?
> > In other words:
> Magic! This works
> Thanks, John!
> help system.
Meanwhile I disovered that
- Hamish's version works for g.list
- John's version works for g.setproj
One takes input piped from stdin, the other from a filename. (?)
xmessage can't figure this out automatically and needs to be told which
one it is getting.
I don't know how to get a shell script to do both. "read" strips
whitespace from between words, how else to read from stdin?
Again I'd push for a g.message C module which takes input from stdin or
a file and makes a Tcl display window ala a module started with no
options.
Sorry, I was sleeping during the first part of this thread, so I'm
probably missing some of the requirements for what you're looking for. But
is this where you'd go like
cat $* | xmessage -file -
in bash? In a script, this should work whether you give a filename on the
command line or just let it read stdin. (It'll actually concatenate any
number of named files, obviously.)
> > > > In other words:
> > > Magic! This works
> > GUI.
> GRASS_PAGER doesn't behave the same...
one it is getting.
options.
Good idea. Let's do this in CVS once 6.0.0 is out or the release
branch created (soonish).
