Howdy folks,
On Tue, Nov 21, 2000 at 07:59:32PM +0000, Markus Neteler wrote:
Hi Jeshua and all,
I have updated all malloc -> G_malloc in
src/display/devices/XDRIVERcvs up src/display/devices/XDRIVER
gmake5 src/display/devices/XDRIVERPlease tell me if it is o.k. now.
OK, I updated the source and ran gmake5.
And I got a bunch or errors like: SWITCHER.c:1396: illegal expression, found `>>'
So, I edited the SWITCHER.c file and deleted the lines that were <<<<<<<<, =========. >>>>>>> and deleted the old malloc statements to get to the next step.
Then, I ran gmake5 again to get these errors:
SWITCHER.c: In function `xalloc':
SWITCHER.c:1369: conflicting types for `malloc'
/System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:121: previous declaration of `malloc'
SWITCHER.c:1369: warning: extern declaration of `malloc' doesn't match global one
SWITCHER.c:1369: conflicting types for `realloc'
/System/Library/Frameworks/System.framework/Headers/bsd/stdlib.h:125: previous declaration of `realloc'
SWITCHER.c:1369: warning: extern declaration of `realloc' doesn't match global one
make[1]: *** [OBJ.powerpc-apple-darwin1.2/SWITCHER.o] Error 1
make: *** [all] Error 2
So then I edited SWITHCER.c again and deleted line 1369 (where mallox and realloc were re-defined).
Raster.c: In function `Raster_int':
Raster.c:83: warning: assignment from incompatible pointer type
Raster.c:85: warning: assignment from incompatible pointer type
cc -o /usr/local/grass-5.0b/driver/XDRIVER OBJ.powerpc-apple-darwin1.2/SWITCHER.o OBJ.powerpc-apple-darwin1.2/Box_abs.o OBJ.powerpc-apple-darwin1.2/Can_do.o OBJ.powerpc-apple-darwin1.2/Color.o OBJ.powerpc-apple-darwin1.2/Cont_abs.o OBJ.powerpc-apple-darwin1.2/Clr_table.o OBJ.powerpc-apple-darwin1.2/Draw_line.o OBJ.powerpc-apple-darwin1.2/Get_w_box.o OBJ.powerpc-apple-darwin1.2/Get_w_line.o OBJ.powerpc-apple-darwin1.2/Get_w_pnt.o OBJ.powerpc-apple-darwin1.2/Graph_Clse.o OBJ.powerpc-apple-darwin1.2/Graph_Set.o OBJ.powerpc-apple-darwin1.2/Panel.o OBJ.powerpc-apple-darwin1.2/Plylne_abs.o OBJ.powerpc-apple-darwin1.2/Polygn_abs.o OBJ.powerpc-apple-darwin1.2/Returns.o OBJ.powerpc-apple-darwin1.2/Serve_Xevent.o OBJ.powerpc-apple-darwin1.2/alloc.o OBJ.powerpc-apple-darwin1.2/command_pend.o OBJ.powerpc-apple-darwin1.2/Raster.o ./lib/LIB.powerpc-apple-darwin1.2/driverlib.a /usr/src/grass/grass/src/libes/LIB.powerpc-apple-darwin1.2/libD.a /usr/src/grass/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a -L/usr/X11R6/lib -lSM -lICE -lX11
/usr/bin/ld: Undefined symbols:
__XErrorFunction
__XIOErrorFunction
__Xdebug
make[1]: *** [/usr/local/grass-5.0b/driver/XDRIVER] Error 1
At which point I get stumped! (Heeeeelp!)
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
