On Saturday, December 2, 2000, at 10:09 AM, Andreas Lange wrote:
I have already send an instruction on how to deal with the errors below.
Please remove the files you edited by hand _before_ updating your local
CVS copy. Otherwise you'll get the conflicts, that have to be resolved
manually, what is not what you want to do.To repeat: remove the file connect.c, do a cvs update -dP and recompile
then with gmake5 or with make install from the top directory (like in
the instruction from Markus).Please send the header file (src/CMD/head/head.powerpc-apple-darwin1.2)
to the list, so that we can check if the X11 libraries are included.It is always complicated to do this sort of remote-diagnosis, i am not
familiar with BSD and Darwin/Mac OS X and i don't know which level of
expertise to expect from you. So please ask if you do not understand
something.
Thanks Andreas and Eric!
After deleting and updating connect.c, it compiles just fine. I still get the error:
__XErrorFunction
__XIOErrorFunction
__Xdebug
Here's by header file:
CC = cc
FC =
LEX = flex
YACC = yacc
ARCH = powerpc-apple-darwin1.2
MAKE = make
prefix = /usr/local/grass5
exec_prefix = /usr/local
GISBASE = /usr/local/grass5
UNIX_BIN = ${exec_prefix}/bin
DEFAULT_DATABASE =
DEFAULT_LOCATION =
COMPILE_FLAGS = -g -O2
LDFLAGS =
DLLIB =
XCFLAGS = -I/usr/X11R6/include
# XXX - replace SYSV in code with configure results in config.h
# XXX - need SYSV defined for hpux10
XLDFLAGS =
XINCPATH =
XMINCPATH =
XLIBPATH = -L/usr/X11R6/lib
XTLIBPATH =
XMLIBPATH =
XLIB = -lSM -lICE -lX11
XTLIB = -lXt
XMLIB = -lXm
XEXTRALIBS =
COMPATLIB =
TERMLIB =
CURSES = $(TERMLIB) $(COMPATLIB)
MATHLIB =
XDRLIB =
ZLIB = -lz
#PostgreSQL:
PQINCPATH =
PQLIBPATH = -L/usr/lib -L/usr/local/lib
PQLIB =
#ODBC:
ODBCINC =
#Image formats:
PNGINC = -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include
PNGLIB = -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib
#JPEGINCPATH = -I/usr/X11R6/include/ -I/usr/include/gr -I/usr/local/include -I/usr/include
#JPEGLIBPATH = -L/usr/local/lib -L/usr/X11R6/lib -L/usr/lib
JPEGINCPATH =
JPEGLIBPATH =
JPEGLIB =
TIFFINCPATH = -I/usr/local/include
TIFFLIBPATH = -L/usr/local/lib
#openGL files for NVIZ/r3.showdspf
OPENGLINC = -I/usr/local/include/GL -I/usr/X11R6/include/GL
OPENGLwINC =
OPENGLLIB = -L/usr/lib -L/usr/local/lib -L/usr/lib/X11 -L/usr/X11R6/lib -lGL
OPENGLULIB =
LGLWM =
#tcl/tk stuff
TCLINCDIR = -I/usr/local/include
TKINCDIR = -I/usr/local/include
TCLTKLIBPATH = -L/usr/local/lib
TCLTKLIBS =
LIBRULE = ar ruv $@ $?; ranlib $@
USE_TERMIO =
# Uncomment below to input Korean(Asian?) characters in v.digit or etc.
#DASIAN_CHARS = -DASIAN_CHARS
# It's hard to click two buttons simultaneously with two button mouse.
# Situation is worse, if it requires continuous clicking.
# In this case uncomment below.
#DANOTHER_BUTTON = -DANOTHER_BUTTON
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
