Jeshua Lacock wrote:
> On Thu, Nov 30, 2000 at 02:18:04AM -0800, Markus Neteler wrote:
> > Hi Jeshua,
> > please
> > cvs update src/display/devices/XDRIVER
> > cd src/display/devices/XDRIVER
> > gmake5
> > and send the errors. Please add, if the references to
> > > > __XErrorFunction
> > > > __XIOErrorFunction
> > > > __Xdebug
I got the XDRIVER compiled! I figured out what caused the problem. The XDRIVER instructions said to run ranlib *.a on the lib which is what caused the problems!
> I just updated the entire tree and In order to compile connect.c, I had to move
connect.c.orig to connect.c. The errors I got were a bunch of messages like
"connect.c:73: illegal expression, found `<<'" (I have a hunch that it is checked out
our something...).
> I got some errors about malloc and realloc, so I deleted line 1369 in SWITCHER.c to get it
working.
What should I do about this? Eric recommend against deleting the line, I do not now what else to do.
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
subject 'unsubscribe grass5'
