[GRASS5] New operation to v.select: noverlap
Hi!
This patch adds another option to v.select, "noverlap". This is the
opposite of overlap. So all fetaures not in b are selected from a.
I haven't really tested this with all kinds of areas, so it might still
be buggy, but please try it out and let me know. I'll happily fix any
buggs I have added.
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
(attachments)
v.select.noverlap.patch (3.45 KB)
Thanks, Wolf...
I recently had the need for "a contains b" and "a is-contained-by b" in v.select. Any chance you want to add these as well, since you're on a roll ? :slight_smile:
Allan
Thanks, Wolf...
Ahmm.. I'm not sure I would know how to do that. The noverlap was easy,
since there was no need to do any checking. All I had to do was reverse
the overlap case. But it sounds like an interesing challange. I'll
probably do it, but no promises! (;
--W
Allan, good news! I just figured out a way to do the contains operator.
is contained by can be doe by reversing a and b.
Here is what I plan to do, this is a bit technical, but it will serve as
a project plan (;
* Check that every point of B is in A by calling Vect_point_in_area()
* If this is true, then check that all points of A are not included in
  B with the same function. This is to ensure that A does not
  contain surprises like this:
| | *| A |
| | B| |
Here A does not contain B (even if all ponts of B are inside A), because
of the "bay" marked by *.
Markus, Radim how does this sound?
--Wolf
Thanks, Wolf...
--W
It sounds good but v.select works for the whole map,
is it your intention to check individual features?
Note this case:
Radim
a project plan (;
| | *| A |
| | B| |
--Wolf
>>Thanks, Wolf...
> --W
Yes, that is the only case that I can think about. I know that this is
potentially a very timeconsuming task, but is there any other way?
Note this case:
Hmm.. Argh.. is there any way to detect this case?
--Wolf
