we have a new outgoing directory for code submissions
which wait for integration into GRASS:
We have just found that s.vol.rst has broken segmentation - we have a
good version, however
somebody has probably changed something (e.g. it gives a message
"adjusted DMIN = .... which does not make much sense, because I don't
see a reason why dmin
would have to be adjusted)
Is there any way to find out what was done to it, why and who changed
it?
We could replace it with our version but then whatever useful was done
will be gone.
thanks,
Helena
On Wed, Apr 24, 2002 at 05:08:53AM -0500, Helena wrote:
We have just found that s.vol.rst has broken segmentation - we have a good
version, however somebody has probably changed something (e.g. it gives a
message "adjusted DMIN = .... which does not make much sense, because I
don't see a reason why dmin would have to be adjusted)
Helena,
I added a test for the 3D sites data, but cannot remember to have changed
anything with "adjusted DMIN". The cvs diff doesn't display the
initial version for some (strange) reason:
cvs diff -r 1.1 main.c
cvs server: main.c is a new entry, no comparison available
While
cvs diff -r 1.2 main.c
is fine (and showing the added test).
it?
Yes:
cvs2cl.pl
http://www.red-bean.com/~kfogel/cvs2cl.shtml
If you run this script in a CVS directory, you get a file
Changelog
will be gone.
We can use "diff/patch" to merge both versions.
> don't see a reason why dmin would have to be adjusted)Helena,
initial version for some (strange) reason:cvs diff -r 1.1 main.c
cvs server: main.c is a new entry, no comparison availableWhile
cvs diff -r 1.2 main.cis fine (and showing the added test).
The reason is that s.vol.rst was added to the release branch first; it
didn't exist on the head until the latest merge.
