Colleagues and co-conspirators
I’d like those of you with different systems to test this script if you could. As part of my updates to the GIS Manager, I’ve expanded the functionality of d.out.png.
The script I’ve attached here—d.out.file—will export the current display monitor to several different file formats: PNG and PPM (using Glynn’s update of the PNG driver) from the PNG driver, and to TIFF, JPEG, and BMP using gdal_translate. PNG compression, JPEG compression, and selections for transparent background, white (now default), and black backgrounds are supported.
If this works OK on other systems besides my Mac (OSX 10.4), I’ll add it to the CVS to replace d.out.png.
Thanks much
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
(attachments)
d_out_file.tgz (2.76 KB)
I¹d like those of you with different systems to test this script if you
could. As part of my updates to the GIS Manager, I¹ve expanded the
I have tested the script on PIII 450Mhz 192MB Linux Debian Testing with grass6.1-cvs and AMD 3000+ 32Bit 512MB Linux Fedora Core 3 with grass6.1-cvs.
The script works well, i've tested every output format but not every resolution with every outputformat, only with tif and png.
I've used the spearfish dataset and visualized raster maps, vectors, labels and the scalarbar. Looks good, but the black or transparent background didnt worked. I watched the pictures with gimp 2.something.
Besides background and transparency the script work very well.
Best regards
Soeren
The script I¹ve attached hered.out.filewill export the current display
monitor to several different file formats: PNG and PPM (using Glynn¹s update
supported.
If this works OK on other systems besides my Mac (OSX 10.4), I¹ll add it to
Thanks much
Michael
phone: 480-965-6213
fax: 480-965-7671
Soeren,
Thanks for the testing.
For the transparent and black/white background options, I used
export GRASS_BACKGROUNDCOLOR=
export GRASS_TRANSPARENT=
that are listed in the PNG driver documentation.
Do these do what they claim to do? I'm not sure how to test.
Michael
USA
voice: 480-965-6262; fax: 480-965-7671
From: Soeren Gebbert <soeren@pool.math.TU-Berlin.DE>
Date: Tue, 6 Sep 2005 12:18:33 +0200 (CEST)
To: Michael Barton <michael.barton@asu.edu>
Cc: Grass Developers List <grass5@grass.itc.it>
Subject: Re: [GRASS5] New script for monitor output to multiple formats
grass6.1-cvs.
Best regards
Soeren
The script I¹ve attached here‹d.out.file‹will export the current display
supported.
Thanks much
Michael
phone: 480-965-6213
fax: 480-965-7671
