[GRASS5] New TclTk interface for GRASS 5
For the past couple months, I've been developing an update to the venerable TclTk menu system for GRASS 5. Besides reorganizing the menu hierarchy, I've added all the rest of the GRASS commands that are not in the standard menus (about 200 new ones in all) along with commands to produce fairly nice looking output from GRASS screens as graphic image files you can paste into other applications (in *.xwd, *.tiff [8 bit color], and *.png formats).
It has been tested pretty extensively and will soon go into the CVS for GRASS 5.3. It is designed for GRASS 5.3, but should work pretty well for GRASS 5.0.3 also (except where GRASS 5.3 modules have new options not available in GRASS 5.0.x). If you'd like to use it with your current GRASS installation, you can download the complete menus (as a *.tar.gz file) along with instructions for installing them at
http://www.public.asu.edu/~cmbarton/grass.htm
If you have any questions, let me know.
Enjoy!
Michael Barton
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Wow, sounds great!
I wonder if the idea to automatically generate the tcltk menus
from the output of the commands was used for your work.
Looking forward to checking it out. Cheers.
I'm just curious what's the point of making huge .xwd files when
.png's are a lossless (via xwdtopnm | pnmtopng) version of the same
thing at 1% the size?
regards,
Hamish
If you are creating temporary images which will be read by another
program then deleted, there's no point wasting CPU cycles on
compression.
Having said that, I would guess that the XWD option corresponds to
using xwd to grab the contents of an XDRIVER window. Similarly, I
would guess that the TIFF option corresponds to using the CELL driver
plus r.out.tiff.
Dr. Barton -
Do you have any info on compatibility with GRASS 5.7?
- Jeff
Enjoy!
Michael Barton
<fontfamily><param>Helvetica</param>______________________________
USA
voice: 480-965-6262; fax: 480-965-7671</fontfamily>
