[GRASS5] new v.to.rast2 arrived
from Politecnico di Milano, Marco Negretti, I have received an improved
v.to.rast which improves the vector/raster conversion. Find details
below (the presentation contains self-speaking images).
Question is if we update the current v.to.rast with this improved
version (I would say yes...).
The details algorithm description will follow later as it is currently
to be translated into English.
Regards and many thanks to Marco!
Markus Neteler
On Fri, Mar 23, 2001 at 03:20:35PM +0100, Marco Negretti wrote:
Ciao Markus,
I enclose the 'main.c' and an extract, translated in english, from the Trento presentation: i hope it'll be useful to understand the
code.
The presentation is available in italian at
http://www.ing.unitn.it/~zatelli/grass_days_2001/it/slides/grass_days_2001_negretti_biagi.pdf
If you need any help, please let me know.
Marco
Marco Negretti
Politecnico di Milano - Facoltà di Como
via Valleggio, 11 - Ufficio V2.8
22100 Como (ITALY)
fax (+39) 031.332.7519
e-mail marco@torno.ing.unico.it
http://geomatica.ing.unico.it
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
subject 'unsubscribe grass5'
if it is well tested both for lines and polygons at least byt its author it would be worth replacing.
Are you going to put it into GRASS5.1 ?
Also, we gave you v.to.rast2 which should not be called v.to.rast2 but
rather v.to.rastdir, because it produces the direction of the line in the resulting
raster (this may be useful not only for modeling preferential flow but
also for getting map of directions for a hiking path, etc.) . It my be worth it
to have Marco look at it and add it as an option or flag into his program
so that we don't have too many modules - it should be simple to implement
Let me know if more explanation is needed for that option or whether I should write
to Marco directly.
Helena
Neteler wrote:
Markus Neteler
> Ciao Markus,
> code.
> Marco
> Marco Negretti
> 22100 Como (ITALY)
Helena,
On Sat, Mar 24, 2001 at 03:20:30PM -0600, Helena wrote:
Well, that's the question... (now or later).
resulting raster (this may be useful not only for modeling preferential
flow but also for getting map of directions for a hiking path, etc.) . It
my be worth it to have Marco look at it and add it as an option or flag
into his program so that we don't have too many modules - it should be
simple to implement
Yes, we should merge these modules. I would be glad if you could talk to
Marco directly (I think he's not on this list) how to proceed.
to Marco directly.
Helena
Thanks in advance,
Neteler wrote:
> Hi all,
> Markus Neteler
> > Ciao Markus,
> > code.
> > Marco
> > Marco Negretti
> > 22100 Como (ITALY)
Hi Markus
Unless this new code fixes a bug, it should be saved for 5.1 since you
have stated that the socket code was the last feature. Once the release
branch is created, you can add the new code to the MAIN branch.
Just my 2 cents worth.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
I have added new code to go into 5.1 in CVS:
grass51/notyetuploaded/
new_makefile_system/ -> from Eric Mitchell
                           automake
r.carve/ -> from Helena et al.
                          The program will take the vector stream data,
                          transform them to raster, and subtracts a
                          defaultdepth+additionaldepth from the DEM.
v.to.rast2/ -> from Marco Negretti
                          (This command allows the rasterization of GRASS
                           vector data. The 'old' method is available: it
                           is called by the G_system command;
                     In this function 2 new rasterising methods are available.
                        -1) dominant unit rastering;
                        -2) importance method.
v.to.rastdir/ -> from Helena et al.
                               This is a new version of v.to.rast. It has
                               the following features:
                              (1) It does not use a temporary file. Results
                               go directly to the raster map. It does this
                               by making one or more passes thru the vector
                               map, rasterizing only a fixed number of rows
                               (in memory, default 512), writing these rows
                               to the raster map, and then repeating for the
                               next set of rows, etc;
                              (2) The line drawing algorithm is better. The
                                  original version of v.to.rast moved each
                                  line to the nearest grid-cell center
                                  before rasterizing. This version more
                                  nearly reflects the actual path of the
                                  vector lines through the grid cells; and
                              (3) It works for lat/lon databases as well as
                                  planimetric databases.
I assume the v.to.rast2 and v.to.rastdir should be merged in near future.
