[GRASS5] Newbee problem starting grass5 on Win2K
I install cygwin, XFree86 and GRASS 5.0 precompiled
When I start grass5 with the followin command
/usr/local/bin/grass5
The first screen is this:
WELCOME TO GRASS Version 5.0.0pre2 September 2001
1) Have at ....
2) When working on your ...
3) Check the GRASS webpage for feedback...
Hit RETURN to continue
Then when I hit RETURN, the following message apears:
Error opening terminal: xterm.
Invalid resource file, removing /administrator/.grassrc5
administrator@SIG ~
What am I doing wrong?
if I type xterm... it works fine.....
Thank you for your help
Kenneth Cabrera
Universidad Nacional de Colombia
Sede Medellin
This means that xterm's terminfo file can't be located (it should
exist as /usr/share/terminfo/x/xterm). Ensure that you have installed
the "terminfo" package.
