[GRASS5] newbie question: location, mapset, layer relationship
hello,
I want to create the test data for area "150km * 150km". According the "grass5" manual, it seem that I should create a location, then create a mapset. My question is:
1. Which module is for creation of location?
2. Which module is for creation of mapset?
3. I want to create a layer for customer, and a layer for road. In "mapinfo", mapset consists of layers. But in "grass", I can't find the concept of layer, just "raster map" and "vector map". Are "layer" and "raster map", "vector map" are the same concept?
Thank you for your reply.
Best regards
chenyu
_________________________________________________________________
MSN 8 helps eliminate e-mail viruses. Get 2 months FREE*. http://join.msn.com/?page=features/virus
Both of these operations are performed from the start-up screen (in
text mode; use "grass5 -text" if necessary).
If you enter the name of a non-existent location and/or mapset, it
will ask if you want to create a new location/mapset.
Probably.
All maps within a location should share the same projection, so you
can display them on top of one another and everything should align.
