to get the make process little more common I propose
to remove the
src/CMD/next_step/*
when invoking
make install
Then compilation always starts from the beginning. The reason for
this change is to minimize difficulties for new users in case of
library changes: now they would have to remove the next_step file
manually. As the computers are quite fast nowadays it doesn't matter
if the compilers hunts through all the directories.
I would add
rm src/CMD/next_step/*
into Makefile/do-install: section.
This is not very elegant, but the make process is subject to change
soon anyway.
If there are no objections, I will upload to CVS later.
subject 'unsubscribe grass5'
