[GRASS5] No fp support in r.reclass
Does r.reclass have fp support? With me it reads fp numbers, but then rounds them to ints.
Looks like I will have to spend some more hard disk space using mapcalc :frowning:
Gualter
Hi Gualter,
r.reclass is doing a reclassification of data. The resulting classes
are integer by definition as a class is generally a whole number.
Probably you have a different application in mind?
(cc grass5)
On Wed, Feb 27, 2002 at 12:26:01PM +0000, Gualter Barbas Baptista wrote:
Markus Neteler wrote:
>Hi Gualter,
Yes. I made a relative index ranging from 0 to 1, but I have some
numbers above 1 (outliers). The idea was to reclass all the numbers
above 1 to -1, leaving the others the same. If I run d.reclass it will
reclass all my pixels to -1, 0 or 1.
I managed to do the same with r.mapcalc, but this takes much more time,
hard disk and CPU. Also, I could just multiply by 100, but then this
wouldn't be so nice to show.
Have a look at r.recode. That allows you to change
a range of data to something different.
Hope this helps,
