[GRASS5] no links to GRASS 5.4 binaries
I went to update the GRASS page on my website to list access to GRASS 5.4. I found that the links to “GRASS 5.4” precompiled binaries on the GRASS website still link to 5.3 versions. I assume that there are 5.4 versions but that whoever maintains this page just hasn’t gotten around to updating the links. I know that you all have sooo little to do… :wink:
Michael
School of Human, Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Hello Michael
found that the links to ³GRASS 5.4² precompiled binaries on the GRASS
that whoever maintains this page just hasn¹t gotten around to updating the
links. I know that you all have sooo little to do... :wink:
When I updated download.html for 5.4 I linked the Linux and Cygwin binaries to the 5.3 links as there were no binaries for them yet. Only 5.4 binaries for OSX are on the server. The links can be updated when binaries appear. Is there somewhere else needs fixed? You can do it in cvs:
cvs co web
Paul
On Thu, Nov 25, 2004 at 09:49:10AM +0000, Paul Kelly wrote:
Hello Michael
>I
>but
appear.
Is there any volunteer to compile 5.4 binaries (Linux etc)?
cvs co web
All developers with CVS write access can modify web pages.
i have compiled 5.4 with this configure output:
GRASS is now configured for i686-pc-linux-gnu
   Build Mechanism: gmake
   Source directory: /home/florian/Documents/SRCes/grass-5.4.0
   Build directory: /home/florian/Documents/SRCes/grass-5.4.0
   Installation directory: /usr/local/grass54
   C compiler: gcc -g -O3
   C++ compiler: c++ -g -O2
   FORTRAN compiler: g77
   NVIZ: yes
   X11 support: yes
   JPEG support: yes
   TIFF support: yes
   PNG support: yes
   Tcl/Tk support: yes
   PostgreSQL support: yes
   OpenGL(R) support: yes
   SGI IRIS GL support: no
   ODBC support: yes
   FFTW support: yes
   BLAS support: yes
   LAPACK support: yes
   Motif support: no
   FreeType support: yes
   GLw support: no
   NLS support: no
   Readline support: yes
   C++ support: yes
   External PROJ.4 support: yes
   GDAL/OGR support: yes
i can make the binary distribution if there is interest.
regards
florian
  NVIZ: yes
  X11 support: yes
  JPEG support: yes
  TIFF support: yes
  PNG support: yes
  Tcl/Tk support: yes
  ODBC support: yes
  FFTW support: yes
  BLAS support: yes
  LAPACK support: yes
BLAS and LAPACK should be: "no" as there is nothing
which uses the libs (still, may change soon).
  Motif support: no
  GLw support: no
With Motif and GLw "yes" a few more modules would be
available (r3.something and xganim).
  NLS support: no
  C++ support: yes
Most welcome! Thanks
You should use --enable-gmake=no or --disable-gmake (this is the default) to get shared libraries. This is important if you are making a binary package available for download as it will be much smaller.
Paul
i have re-compiled it with all your suggested changes. configure now looks like this:
   Build Mechanism: Alternate
   Build directory: /home/florian/Documents/SRCes/grass-5.4.0/build
   NVIZ: yes
   X11 support: yes
   JPEG support: yes
   TIFF support: yes
   PNG support: yes
   Tcl/Tk support: yes
   ODBC support: yes
   FFTW support: yes
   BLAS support: no
   LAPACK support: no
   Motif support: yes
   GLw support: yes
   NLS support: no
   C++ support: yes
you can download it here: http://www.geographen.org/files/grass5.4.0_i686-pc-linux-gnu.tar.gz
in that archive you find the binary archive and the installer script.
florian
looks like this:
  Build directory:
  NVIZ: yes
  X11 support: yes
  JPEG support: yes
  TIFF support: yes
  PNG support: yes
  Tcl/Tk support: yes
  ODBC support: yes
  FFTW support: yes
  BLAS support: no
  LAPACK support: no
  Motif support: yes
  GLw support: yes
  NLS support: no
  C++ support: yes
Great - nearly realtime.
I have downloaded the package but found it rather large as
it was compiled with -g (debugging) and without -s (stripping).
To be discussed: Should this package come with debugging symbols?
Otherwise
CFLAGS="-O3" LDFLAGS="-s" ./configure ...
will help to make it smaller.
probably not! with these options the package is just 13mb big. get it here:
http://www.geographen.org/files/grass5.4.0_i686-pc-linux-gnu_small.tar.gz
florian
here:
Thanks Florian.
The 5.4.0 Linux binaries are published now:
http://grass.itc.it/grass54/binary/linux/
(on the mirrors soon)
Do we still have the rule that NVIZ should be built without PostgreSQL
support?
> Motif support: no
> GLw support: no
xganim requires Motif; r3.showdspf requires Motif and GLw.
> NLS support: no
Is there any reason do disable NLS on Linux? It shouldn't require any
additional libraries (the gettext family are part of GNU libc).
This is a bad idea. On a number of Linux distributions, libreadline
requires a termcap library (libtermcap, libtinfo, or lib[n]curses),
but doesn't list one as a dependency.
On those platforms, an r.mapcalc binary which uses readline won't
work, which is a serious problem.
The --with-readline switch should only be used if you're building for
yourself, or for a specific distribution where that switch is known to
work.
support?
when i switch postgreSQL og i get this:
Compilation error in module: src.contrib/GMSL/NVIZ2.2
  Motif support: no
  GLw support: no
  NLS support: no
it doesn't. i switched it on.
work.
without readine support i get an error on my system:
Compilation error in module: src/raster/r.mapcalc3
florian
You need to run "make clean" (or maybe "make distclean") before
re-running configure with different options.
i did that.
i did that.
So what are the actual error messages you get when you build with
those options disabled?
i did that.
r.mapcalc3:
/home/florian/Documents/SRCes/grass-5.4.0/build/src/raster/r.mapcalc3/lex.yy.o(.text+0x11f7): In function `yy_get_next_buffer':
/home/florian/Documents/SRCes/grass-5.4.0/src/raster/r.mapcalc3/mapcalc.l:58: undefined reference to `readline'
/home/florian/Documents/SRCes/grass-5.4.0/build/src/raster/r.mapcalc3/lex.yy.o(.text+0x1261):/home/florian/Documents/SRCes/grass-5.4.0/src/raster/r.mapcalc3/mapcalc.l:69: undefined reference to `add_history'
collect2: ld returned 1 exit status
make[1]: *** [/home/florian/Documents/SRCes/grass-5.4.0/build/dist.i686-pc-linux-gnu/etc/bin/cmd/r.mapcalc] Error 1
nviz:
*** PostgreSQL unsupported ***
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x12c):
In function `runPg':
/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:34:
undefined reference to `PQsetdbLogin'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x13a):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:36:
undefined reference to `PQstatus'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x155):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:43:
undefined reference to `PQexec'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x163):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:44:
undefined reference to `PQresultStatus'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x17c):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:45:
undefined reference to `PQerrorMessage'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x19c):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:47:
undefined reference to `PQclear'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x1aa):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:48:
undefined reference to `PQfinish'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x1bf):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:52:
undefined reference to `PQnfields'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x1cd):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:53:
undefined reference to `PQntuples'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x230):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:86:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x23e):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:89:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x259):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:64:
undefined reference to `PQfname'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x2a6):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:66:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x341):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:72:
undefined reference to `PQgetvalue'
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x410):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:57:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x439):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:58:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x49e):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:37:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x619):
In function `do_query':
/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:122:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x627):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:124:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x642):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:131:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x650):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:132:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x669):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:133:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x689):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:135:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x697):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:136:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x6ac):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:140:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x6ba):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:141:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x71d):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:173:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x72b):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:176:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x746):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:152:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x78e):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:154:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x829):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:160:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x8f7):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:145:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x920):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:146:
/home/florian/Documents/SRCes/grass-5.4.0/build/src.contrib/GMSL/NVIZ2.2/src/runPg.o(.text+0x98b):/home/florian/Documents/SRCes/grass-5.4.0/src.contrib/GMSL/NVIZ2.2/src/runPg.c:125:
make[3]: *** [nvwish] Error 1
make[2]: *** [dir] Error 2
make[1]: *** [nvwish] Error 2
regards
>> i did that.
r.mapcalc3:
Line 58 of mapcalc.l is within a block which is conditionalised upon
HAVE_READLINE_READLINE_H:
  #ifdef HAVE_READLINE_READLINE_H
    if (isatty(fileno(input_stream)))
      char *line_read;
      line_read = readline("mapcalc> ");
The error indicates that the build is trying to use an object file
from a previous build attempt, when --with-readline was used.
You need to clean up the previous build. If you used the gmake build
mechanism (--enable-gmake), "make distclean" should do this. If you
used the alternate build mechanism (--disable-gmake, which should be
the default for 5.4), simply delete the entire build directory (with
"rm -rf").
nviz:
runPg.c:34:
Same error (trying to use object files from a previous build with
different configure switches).
On 26/11/2004, at 9:34 PM, Glynn Clements wrote:
r.mapcalc3:
      char *line_read;
"rm -rf").
that's what i thought when i checked the source, but deleting the whole build directory didn't solve it.
regards
>> r.mapcalc3:
> char *line_read;
> "rm -rf").
It may be that some files (e.g. include/config.h) are left over in the
source directory from your original gmake-based build. Re-run
configure from the source directory with --enable-gmake, then run
"make maintainer-clean". Then do a non-gmake build.
It definitely works without --enable-readline, and binary
distributions should be built without that switch.
i compiled it again from a "freshly" unzipped source and it now works. you can get the binary package and the installer script at www.geographen.org/files.htm
regards
florian
