when sending NVIZ to background on Linux, it get's
stuck - I cannot even 'fg' it. Where should I look
for the problem?
for the problem?
On Mon, Feb 20, 2006 at 12:44:12AM +0100, Markus Neteler wrote:
for the problem?
Funny: pressing 'return' in the terminal helps and
the wish prompt appears. Then it works again.
Any ideas?
Hi Markus,
This behavior is probably because nviz is a reworked wish executable.
This results in odd behavior such as running it in the background, etc.
Probably the best way around this is to go back to using a shell script
to start nviz. I had briefly looked into this a while back but had not
completely gotten around some of the command line argument issues.
Bob
> Hi,
> for the problem?Funny: pressing 'return' in the terminal helps and
Any ideas?Markus
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
