[GRASS5] nviz-bug
Markus,
do not test with lat long, use UTM or other
x,y data to test what Bob is suggesting. You can
use my DEM at
http://www2.gis.uiuc.edu:2280/modviz/hooder/
ascii file hoodtest.ascii
and nviz state files
hoodel*.state
We need to get NVIZ render the standard DEMs
and then look at a fix for lat/long and small values
again.
Helena
subject 'unsubscribe grass5'
Helena,
On Mon, Feb 05, 2001 at 10:56:02AM -0600, Helena Mitasova - staff wrote:
Markus,
use my DEM at
hoodel*.state
ok. Got them and just wrote a script to autogenerate a location
from that file :slight_smile:
again.
But...
The header is unusual:
north: 3470876
south: 3470492
east: 619214
west: 618588
rows: 192
cols: 313
east > west
Is that really o.k.?
Helena,
sorry, I was confused.
coordinates are fine of course.
Helena,
me again: The hoodtest surface comes fine (white, slightly
shaded). But the states file wants "sel.80" file.
Then:
Diagnostic: invalid command name "Nviz_animation_load" -- Load procedure
for panel animation may not be defined
Diagnostic: invalid command name "Nviz_kanimator_load" -- Load procedure
for panel kanimator may not be defined
Diagnostic: invalid command name "Nviz_query_load" -- Load procedure for
panel query may not be defined
Diagnostic: invalid command name "Nviz_mkdspf_load" -- Load procedure for
panel mkdspf may not be defined
Diagnostic: invalid command name "Nviz_sdiff_load" -- Load procedure for
panel sdiff may not be defined
Obviously this is a NVIZ state from GL version?
Please put the sel.80 somewhere for further testing.
