I just got the changes made by Bob Covill from Markus for testing. Here some additional questions.
Compiling and installing went well.
First of all i tried to build a script with d.nviz:
d.nviz input=rpatch1 output=test name=NVIZ profile=south,north dist=2
ht=500 frames=10
The output is attached as "test".
Loading this file in NVIZ brings the output attached in "testoutput".
After that i tried to create a flight "by hand" from north to south and
had no luck. What are steps for that in the keyframe animation panel.
How do i alter the positions for certain keyframes?
Thanks for helping!
Harald
PS. Bob, i tried to send these questions directly to you (bcovill@tekmap.ns.ca) but got the mail back. Tried it with two different mail-adresses from different providers.
(attachments)
test (454 Bytes)
testoutput (294 Bytes)
Hi Bob,
>Thanks for trying the d.nviz program. From your output it appears that
>you only ran it with one point (?). Like r.profile the profile= option
>should be a comma separated series of geographic coordinates tracing >the
>route. To generate these quickly you could run d.nviz with the "-i"
>option which will let you select the path interactively (like >r.profile)
>from the GRASS monitor.
I tried this too. But similar faults occur again. Just to be sure: I have to produce the script with d.nviz. Then in NVIZ i go in the "Scripting"-Menu, load the script and say play?
>I also notice that you are using dist=2 and ht=500. This will give a
>view almost directly down at the DEM. In other words the eye position >is
>2 meters behind and 500 metres above the scene center.
Yes. I got this.
>The email address you tried was correct. I know the site that hosts my
>email will not allow certain attachment types because of potential
>viruses. I suspect that it simply did not like the attachment type >(even
>though it was harmless)??
It did not work without any attachments too. I'm curious about that. Just this mail came back and it does not have any attachments.
>I hope this helps. Let me know any other questions you might have.
Can I only test a "normal" flight from north to south by a script or can this be done with NVIZ-gui too?
Thanks
Harald
