[GRASS5] NVIZ image dump broken?
the NVIZ image dump to TIFF no longer works for me.
The result image is replicated inside the output
file and basically useless.
If I recall correctly, someone modified this recently
(Hamish?).
It works fine for me.
I seem to remember this same problem was reported to the mailing list
just a few days/week ago. You are using 64bit, correct? I've got a
feeling that previous report was 64bit too.
The htdig search engine is broken currently (even a search for "grass"
gives 0 hits), and I can't connect to Gmane - so sorry no link.
Did it work with yesterday's CVS? (lib/ogsf/gs_bm.c change)
(Hamish?).
Mine was just to change a G_fatal_error() to G_warning(), and to guard
against unwanted ".tif.tif" output file extensions. Nothing to do with
rendering (you'll have to ask Bob about that).
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/ogsf/gsd_img_tif.c
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/lib/ogsf/?sortby=date#dirlist
Hamish
Right. I am using 64bit.
No, it's Wednesday monring in Italy and the htdig job is running.
This takes a few hours on the old 500 MHz server... It will be
back in 2 hours from now, I guess. The new server should be way
faster and I can schedule it to mid Pacific Ocean daytime or so.
Yes, I did.
> (Hamish?).
FreeGIS.org
FreeGIS.org
OK, I will try harder. But if you manage to find the mails,
I would be grateful.
thanks
ht/dig is back online; gmane is still down-
here's the thread:
  http://grass.itc.it/pipermail/grassuser/2006-April/033819.html
Hamish
here's the thread:
This is exactly my problem!
Where should I look for that?
Markus,
I took a look at the thread below and it appears that the image is being
read incorrectly on 64 bit machines. The image buffer is created from
gsd_getimage in gsd_prim.c in ogsf. Unfortunately, I am not an expert on
64 bit machines, but I would guess that that either the malloc is wrong
or glReadPixels is wrong. Is an "unsigned long" a different size on 64
bit architecture? It appears that the dimension of the image is correct,
but the image buffer is wrong.
On a separate issue, I have found that with the recent NVIZ I get a
segfault if I try to load a saved state or save a state if I have a
vector/site file loaded. I assume this is due to the recent changes to
the Sites panel, but I have not had time to investigate. If you can
confirm, it should be added to the bugtracker.
Bob
> here's the thread:
Same here,
spearfish60:
nviz -q
Panel -> Vector points
New
bugsites
File -> Save State
filename
<ok>
segfault.
It happens in panel_site.c, proc Nviz_site_save (line 176),
on this call:
  # useatt
  puts $file_hook "[Nsite$i get_att useatt]"
which takes us to get_att() in src/map_obj.c line 1516.
then in
    case SITE:{
        case SV_ATT_USEATT:
it tries atoi(argv[3]) but there is no 4th arguement to convert:
argc=3
  argv[0]=[Nsite21720]
  argv[1]=[get_att]
  argv[2]=[useatt]
  argv[3]=[(null)]
The atoi() is trying to fetch the attribute number for this:
int site_attr_get(Tcl_Interp *interp, geosite * gp, int nattr)
        char buf[1024];
        sprintf(buf, "%d", gp->use_attr[nattr]);
        Tcl_AppendElement(interp, buf);
        return(TCL_OK);
If I change argv[3] to argv[2] it gets rid of the segfault, but I don't
know if that is the intended logic.
Hamish
bit architecture?
Very probably; I would expect long to be 64 bits on a 64-bit system.
If you need a 32-bit type, either use uint32_t from <stdint.h> (C99,
but present on most systems) or use AC_CHECK_SIZEOF in configure.in.
> bit architecture?
GDAL contains such tests:
dnl Check for 64 bit file API
AC_HAVE_LONG_LONG
AC_UNIX_STDIO_64
AC_CHECK_SIZEOF(int)
AC_CHECK_SIZEOF(long)
But I didn't check in detail.
