This is an interesting one. If I execute something like "nviz -q &", nviz
starts up normally with the wish (%) prompt. If I hit enter at the prompt I
am returned to the normal command line prompt and can run other commands
(while nviz is running). When I quit nviz I get the respone on the command
line ...
[1]+ Done nviz -q
which is what I would expect from a command that has been running in the
background.
Out of curiousity try creating a simple startup script with the following:
#!/bin/sh
exec nviz "$0" "$@"
Make it executable and try running it in the background. For example if you
name the script nv_start.sh, try "nv_start.sh elev=dem &" and see if that
works.
Bob
On 12/18/2004, "Huidae Cho" <grass4u@gmail.com> wrote:
Interesting!
Is wish running in background? As I know, a shell-like program cannot be
running in that way because if it's bg'ed or run with "&", /bin/sh or
the login shell takes control of stdin so that users can stay in the login
shell.If it's executed by a script, then it's ok because it's a usual shell
script.Do you mean running "nviz" and executing other programs in the "%" nviz
prompt instead of running "nviz &"?If wish is running in background (wish &), how can you execute wish
functions?
Thank you.
Huidae ChoOn Sat, Dec 18, 2004 at 01:22:50PM +0000, Bob Covill wrote:
It appears that not even wish will run in the background on your system
very strange.
The current nviz IS the old NVWISH executable which was called was called
by
the old nviz shell script. The reason I got rid of the shell script was
because when nviz encountered an error the same un-informitive message
was
generated because it was passed through the script. Also, there are a
number
of error catches in the actual nviz tcl scripts which were completely
ignored
with the old shell startup.
Before reverting to the old startup it would be nice to know why wish
(and
nviz) will not run in the background on some systems. On both of my
RedHat
systems it runs fine both in the background and the foreground.
Bob
>Hi,
>Now nviz is not a *wish script but a shell itself. That's why it prints
>a prompt and we cannot execute it background and inside "d.m &". To fix
>this problem, I think we should go back to NVWISH because running nviz
>foreground is pain.
>You can test this:
> wish &
>prints % prompt and just stop!
>Huidae Cho
>On Fri, Dec 17, 2004 at 09:02:39PM -0400, Bob Covill wrote:
>> Hello,
>> I tried running the latest version of nviz in the background with
>> various options and it seems to work fine. The "%" prompt that you see
>> is perfectly normal. The nviz program is simply a customized version
of
>> the Tcl/Tk "wish" executable. Try executing "wish" on the command line
>> and you should see the same prompt.
>> As for it crashing when it is run in the background, I have no idea.
You
>> might try changing GRASS_MESSAGE_FORMAT environment variable to see if
>> that has any effect.
>> It might help to know what platform and Tcl/Tk version it is failing
on.
>> For me it works on RedHat 7.3 with Tk8.3, and RedHat 9 with Tk8.4.
>> Bob
>> Helena wrote:
>> >Huidae Cho wrote:
>> >>Hi,
>> >>I noticed today that nviz doesn't work if I run it background as
before.
>> >>Similarly, it just stops after displaying a map when it's executed
from
>> >>"d.m &" which is recommended in the welcome message.
>> >>nviz elevation=dem & # doesn't work
>> >>d.m & # nviz doesn't work
>> >>nviz elevation=dem # works!
>> >>d.m # nviz works!
>> >>And I see nviz prints % prompt. Does anyone have a clue?
>> >It must be the latest change that was done - I just tried it and it
>> >does not work even if I do nviz elevation=dem, it displays the DEM
>> >but fails to open the Main pannel and prints a % prompt.
>> >It worked OK just a few days (weeks?) ago.
>> >It may be related to the change in the startup script - Bob, are you
>> >around? How does it work for you?
>> >Helena
>> >>Thanks.
>> >>Huidae Cho
>> >>_______________________________________________
>> >>grass5 mailing list
>> >>grass5@grass.itc.it
>> >>http://grass.itc.it/mailman/listinfo/grass5
grass5 mailing list
grass5@grass.itc.it
