[GRASS5] nviz segfault with grass5.7.0
Dear developers,
i have a problem with nviz, if i try to visualize a rasterfile i get a
segmentationfault:
Loading Data
child killed: segmentation violation
    while executing
"exec /usr/local/grass-5.7.0/etc/nviz2.2/NVWISH2.2 -f
/nviz2.2/scripts/nviz2.2_script -q -name NVIZ >&@stdout"
    ("eval" body line 1)
    invoked from within
"eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
$env(GISBASE)/etc/nviz2.2/scri
pts/nviz2.2_script $argv -name NVIZ >&@stdout"
    invoked from within
"if {$argv == ""} {
#no arguments
$env(GISBASE)/etc/nviz2.2/scrip
ts/nviz2.2_script -name NVIZ >&@stdo..."
    (file "/usr/local/grass-5.7.0/bin/nviz" line 16)
The problem shows up only with rasterfiles.
I think the reason is, that i running a 64Bit
Linux on AMD 3000+ 64Bit. Do you have any hints to solve the problem?
I'm a skilled C-programmer, maybe i can help you?
Best regards
Sören Gebbert
segmentationfault:
Loading Data
[rest is Tcl cruft]
    while executing
    invoked from within
    invoked from within
"if {$argv == ""} {
#no arguments
some things to try first:
Set the region to include data?
g.region rast=rastermap
Is the map's range != 0?
r.info -r rastermap
Debugging NVIZ hints from Glynn
   http://article.gmane.org/gmane.comp.gis.grass.devel/2010
> AFAICT from the error message, it's the core NVIZ process which
> crashed; i.e. not the "nviz" script, but the NVWISH2.2 binary
> interpreting nviz2.2_script. To debug that, you would need to emulate
> the "nviz" script by setting up the various environment variables,
> then running NVWISH2.2 under gdb, e.g.:
> export GISDBASE=`g.gisenv get=GISDBASE`
> export LOCATION_NAME=`g.gisenv get=LOCATION_NAME`
> export MAPSET=`g.gisenv get=MAPSET`
> gdb /usr/local/grass5/etc/nviz2.2/NVWISH2.2
> > run -f /usr/local/grass5/etc/nviz2.2/scripts/nviz2.2_script
> > -name NVIZ
good luck,
Hamish
> segmentationfault:
> Loading Data
[rest is Tcl cruft]
> while executing
> invoked from within
> invoked from within
> "if {$argv == ""} {
> #no arguments
yes, i tried differend regions.
r.info -r rastermap
I have no "working" rastermap (and i have a lot), even the maps from 32Bit
systems are not working. But if i declare a constant in nviz (as map AND color), then it
works.
> > > -name NVIZ
good luck,
Hamish
thanks
Best regards
Sören
Dear developers,
I have used the gdb and now i'm more confused than befor:
I tried to visualize this map:
| Type of Map: raster Number of Categories: 255
| Data Type: FCELL
| Rows: 1579
| Columns: 2257
| Total Cells: 3563803
| Projection: UTM (zone 29)
| N: 4121508.96 S: 4118161.48 Res: 2.12
| E: 558204.48 W: 553419.64 Res: 2.12
| Range of data: min = 13.817110 max = 196.461456
| Data Source:
| vector file Elevation
I get this error:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 182923337952 (LWP 17399)]
0x0000002a96640f33 in G_zero_raster_buf (rast=0xffffffff99a3f010,
data_type=4) at zero_cell.c:34
34 *ptr++ = 0 ;
The G_window_cols() routine in G_zero_raster_buf() says, the window has
2269 cols, so it is bigger than the map.
Ok, i zoomed in and now i get this error:
[Switching to Thread 182923337952 (LWP 17418)]
0x0000003ed19debd6 in xdr_float () from /lib64/tls/libc.so.6
Does someone has a hint?
Best regards
Sören
| Data Type: FCELL
| Rows: 1579
| Columns: 2257
| Data Source:
I get this error:
The data_type parameter should be one of 0, 1 or 2 (CELL_TYPE,
FCELL_TYPE or DCELL_TYPE respectively). You need to obtain a backtrace
and determine how G_zero_raster_buf() comes to be called with
data_type equal to 4.
You may try to build all the packages out of sources / CVS; in particular when using a 64bit platform.
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
Soeren Gebbert schrieb:
Dear developers,
| Data Type: FCELL
| Rows: 1579
| Columns: 2257
| Data Source:
I get this error:
34 *ptr++ = 0 ;
Best regards
Sören
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
