[GRASS5] NVIZ TIFF output (rotated 180 degree)
Hi developers,
it seems that the TIFF output of NVIZ is sometimes rotated 180 degree
depending on the display tool.
xv: ok.
display (image magick): upside down (rotated 180 degree)
gimp: upside down (rotated 180 degree)
Is there anything we can change in NVIZ to stabilize the
image orientation of the stored TIFF file?
Markus,
I had noticed that in the past. The place to look for this problem is in the ogsf library, in gsd_img_tif.c. This file contains the TIFF header info. Probably something in the header is wrong or the actaul image is being written wrong (rows / columns).
Hopefully it is something simple.
Markus Neteler wrote:
Hi developers,
xv: ok.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill@tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
On Thu, Mar 07, 2002 at 09:20:18AM -0400, Bob Covill wrote:
Markus,
Probably
    TIFFSetField(out, TIFFTAG_ORIENTATION, ORIENTATION_BOTLEFT);
is not correct in that file or not sufficient?
Hi TIFF experts... :slight_smile:
> Hi developers,
> xv: ok.
> Thanks,
> Markus
> grass5 mailing list
> grass5@grass.itc.it
Bob Covill
Tekmap Consulting
B2T 1K6
Canada
Phone: 902-860-1496
Fax: 902-860-1498
Probably
It's correct; it's not sufficient in the sense that "display" and
"gimp" (and "tifftopnm") appear to ignore the orientation tag and
assume top-to-bottom.
The workaround is to write the image in top-to-bottom order, as is
done for PPM. I'll commit this shortly.
This is a symptom of the more general problem with TIFF: it has so
many options that most programs which claim to read TIFF images only
read certain TIFF images. If you're creating TIFF images, you have to
discover by trial-and-error which options are supported by which
programs.
