To: "Tom Rake" <duff_maps@hotmail.com>
CC: grass5@grass.itc.it
Subject: Re: [GRASS5] NVIZ Tk8.0 on Debian
Date: Mon, 13 May 2002 09:38:30 +0100Glynn Clements wrote:
> If you send me the tkInt.h for 8.0p5, I'll add it to NVIZ' collection
> of tkInt.h files.
Unfortunately, it appears that this header isn't compatible with Tk
8.0p5. The header references the type Tk_SmoothMethod, which
(according to Tk's ChangeLog) was added on 1999-12-13, but 8.0p5 was
released on 1999-03-09. So, this appears to be a Debian-ism.
Glynn,
Oh well, I was worth a shot. I guess I can just patch my source locally before I build.
Adjusting for debianism and debian version changes and other distro based differences does seem to far to go.
I'll revert the changes.
Ultimately, configure should check for a local tkInt.h file before
attempting to use any of the supplied version. However, that
presumably won't make it into pre4.
Moving towards release is very important.
I sometimes a week or two behind on grass, but if I see changes on this I'll eventually get to a compile and report back. If I get time I may try changes to configure.in (It won't be the first time but I am far from the expert at much of this).
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
Thanks
-tom rake
_________________________________________________________________
Join the world’s largest e-mail service with MSN Hotmail. http://www.hotmail.com
