[GRASS5] NVIZ updates
Hello,
I have just applied a few changes for NVIZ to CVS. These changes are found in the ogsf and NVIZ2.2 directories.
These changes include the following:
1. Added colorbar (legend) support. The colorbar for the currently selected surface (color overlay) can be drawn from the Label panel. All features are working with the exception of "use list". Simply set your features and select the "Legend" button and mark the legend corners in the NVIZ window. Use the left mouse button to set the first corner and the right button to mark the second corner. If the selected points are wider than high, a horizontal bar will be drawn. The font for the legend is controled by the Font options in the label panel. A visible rubberband box is on the todo list for this feature.
2. Added Label support. Labels may now be drawn in the NVIZ window by first setting the label font options (color size, weight, etc), entering the label text in the "Label Text" entry box. Select the "Place Label" button and choose a position in the NVIZ window. The text will be drawn centered and above the selcted point.
3. Added font support. Font are now supported in NVIZ. This option is used in the above legend and labels. Note that the options available create an X compatible font. It is possible to set the options to a font that is not available on your system. You can use glxinfo to view available fonts. An error is printed to stderr if a font is not available. A generic default font should probably be defined in future updates.
4. Added North arrow support. A North arrow can now be drawn by selecting the Scale panel. Select the Place Arrow checkbutton and then the Place Arrow button. Select a location in the NVIZ window. The arrow is drawn originating from the selected point. The arrow can be drawn on a surface or beside a surface. The scaling option for the North arrow still needs some work in ogsf. You may end up with overly large or small arrows.
5. Added height options for vectors. I have cleaned up the vector panel to hopefully be a bit more intuitive. I have also added a height slider to the panel. The user may now draw the selected vector at a set height above the surface(s). This can help portions of the vector from being obscured in the surface(s). The vector can also be drawn flat (Display Flat) at a height set by the slider. Note that if the vector is being drawn flat, a surface must be associated with the vector. If there is no association, nothing will be drawn. This is something that still needs cleaning up. The vector panel should work a bit better now in the case where multiple vectors and surfaces are being drawn.
6. Set the lights to refresh every time a key frame is advanced. When creating a key frame animation output images did not seem to reflect the users light positions (shading). This fix should correct that.
If you have any questions, problems, or comments about any of the changes please let me know.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill@tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
