i need help, while i run grass57, it showed me the following message. could any one help me to solve it? actually, i can find the file 'libproj.so.0', it means the file libproj.so.0 is existed.
GRASS 5.7.-cvs:/home/zxu/grass57_exp_2004_05_08 > d.m
Error in startup script: ps.map: error while loading shared libraries: libproj.so.0: cannot open shared object file: No such file or directory
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/usr/local/grass57/etc/dm/d.m.tcl" line 785)
_________________________________________________________________
Help STOP SPAM with the new MSN 8 and get 2 months FREE* http://join.msn.com/?page=features/junkmail
Hy Zealven,
if you installed proj4 by default,
you should have a /usr/local/lib/libproj.so.0 file.
Does this apply to your case?
If not, where is your proj installation?
while executing
"exec ps.map -p"
invoked from within
"DmPrint::init"
invoked from within
"main $argc $argv"
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
____________________________________________________________________________
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
University of Trento
Department of Civil and Environmental Engineering
Via Mesiano, 77 - Trento (ITALY)
Andrea Antonello
tel: +393288497722
fax: +390461882672
