Well, I can now start GRASS5, but only by using the -text option. Why
assume a GUI default?
When I try to enter location and mapset names, I have no erase capability
(i.e., neither the delete nor the backspace keys work). Is this normal?
When I finally get to the command prompt I try starting a monitor, and
this is what I get:
GRASS:/mnt/usr4/coeur-rochester/data > d.mon start=x0
Sorry, </usr/local/grass5/dev/fifo.1a> not available
Have GRASS adminstrator check etc/monitorcap file
Can't stat /usr/local/grass5/dev/fifo.1a
Problem selecting x0. Will try once more
When I list the monitors, x0 through x6 are shown to be available. So,
what have I left off here?
BTW, this is with beta-11.2.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
Making environmentally-responsible mining happen. (SM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard@appl-ecosys.com
subject 'unsubscribe grass5'
