[GRASS5] Options in Tcltkgrass fixed
Date: Sun, 4 Feb 2001 12:29:02 +0000
From: Markus Neteler <neteler@geog.uni-hannover.de>
Hi Justin,
hi all
On Wed, Jan 31, 2001 at 06:54:01PM +0700, Justin Hickey wrote:
> Hello all
> I fixed the tcltkgrass options list for commands so that flags (like -f
> -m etc) will always be at the beginning of the list. For example for
> g.manual before, the options would be
> g.manual entries=d.rast -d
> Now they are
> g.manual -d entries=d.rast
that's perfect. Thanks for the update.
> Also, I updated the tcltkgrass module for g.manual
> (src/tcltkgrass/module/g.manual) to reflect the options of the script as
> opposed to the options of the command in src/general/g.manual. However,
> somebody familiar with the script needs to fill in the browser parameter
> properly. I had no idea what to do with that. I just put the same thing
> as the entries parameter. Could somebody please take a look at that?
Huidae, as you have been developing the g.manual script, could you
please looking into this?
> BTW, since we are using the script now, can we remove
> src/general/g.manual to avoid confusion?
Generally yes. Now the script will do job.
Any objections to delete src/general/g.manual?
Hi Markus,
I think its code is enough to reflect the browser parameter.
However, this parameter may be somewhat meaningless in the tcltkgrass or GUI.
Yours,
Huidae Cho
subject 'unsubscribe grass5'
