[GRASS5] ossim-grass-bridge milestone 3 summary
Ahh, well my signing it causes the same problem when I get the message
back. More investigation ...
Eric G. Miller <egm2@jps.net>
subject 'unsubscribe grass5'
On Tue, Nov 14, 2000 at 07:26:09PM -0800, Eric G . Miller wrote:
Each of the last several messages you've sent have been unreadable for
me in mutt (which I notice you are also using). It complains:
You too, Eric. Probably the remailer.
James Cameron mailto:quozl@us.netrek.org http://quozl.netrek.org/
Bernhard and Eric,
my mutt likes your mails...
[-- PGP output follows (current time: Wed Nov 15 09:06:02 2000) --]
[-- End of PGP output --]
[-- The following data is signed --]
Such an error I don't have:
[-- Error: Inconsistent multipart/signed structure! --]
Something is adding junk into the mail, specifically I see things like
"=20" which probably should just be newlines. Anyway, I don't know if
it's the remailer or what (I'll try signing my own to see...).
So I guess it's not the re-mailer (as being untouched for month).
You can still read the mails, if you pipe them into less or something.
Interesting, how do you get the mail (excatly?) it might be
your local delivery which makes them go correct on your machine.
Did you change anything on your mail configuration in the last days?
Did you change anything, installing or removing packages.
If you carbon copy the mail to me and the list I can read mine, but not
the one coming from the list, so it must be in the transport mechanism.
And when Eric has the same problems it is likely that the problem lies
more towards Markus' direction.
  Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Due to lack of time I did not change anything :slight_smile:
ls -la /etc/minordomo.conf
-rw-r--r-- 1 root other 1572 Sep 22 09:49 /etc/minordomo.conf
ls -la /WWW/cgi-bin/minorweb.pl
-rwxrwxrwx 1 nobody other 18027 Sep 22 09:51 /WWW/cgi-bin/minorweb.pl
See, nothing changed. The minordomo is pretty straight-forward.
Perhaps I should set up mailman, but my time is really limited
and minordomo working for a long time without complaints.
My mutt is Mutt 1.2.5i (2000-07-28) on SUN/Solaris2.6.
Beside a missing possibility to scroll the alias name list, I like it.
Both mails have been looking identical.
Maybe yes. But what can I do?
But you can! Just hit tab when you have to enter an email address... :slight_smile:
When I have time I will investigate. It could also be in the mail
transport mechanism at your university.
  Bernhard
Brilliant :slight_smile: I am reading documentation only as last resort...
Aha, I will call them to investigate.
Thanks for the mutt hint,
