Hello all
Is there a way in tcltkgrass to have the output window automatically
destroy itself for a particular module? With the change to d.rast to
output a percentage indicator, tcltkgrass pops up a window to display
this output. However, by default, the user must close the window
directly, which is a pain in this case. Can we change this behaviour for
d.rast so that it automatically closes?
The proper thing to do would be to have d.rast pop up a process
indicator (I think there is one in bwidget) that is destroyed when
complete but I'm not sure how much work that would be.
What do you think?
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey@hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
subject 'unsubscribe grass5'
Hi Justin,
On Thu, May 10, 2001 at 03:16:43PM +0700, Justin Hickey wrote:
Hello all
a small sidenote: I have added this percentage output due to the changes
in XDRIVER - when drawing large maps, you may wait a few seconds until
the image is draw completely in one step. In past, with line-by-line
drawing in d.rast the user has been seeing what's ongoing. To avoid
confusion, d.rast chats now.
However, these left-over windows (some other modules are affected, too),
are quite inconvenient. Maybe the messages could be directly printed into
a tcltkgrass module window?
| d.rast |
|Raster map to be displayed: |
| ______________ raster |
|o Overlay |
|d.rast_____________________ |
| New message board | <- here all related messages should
+_____________________________+ appear instead of opening another
window.
This would definitly improve the optical impression of tcltkgrass.
Question is how the G_percent() communicates with external modules...
Just my 0.02 Euro,
Hi Markus
changes in XDRIVER - when drawing large maps, you may wait a few
seconds until the image is draw completely in one step. In past, with
line-by-line drawing in d.rast the user has been seeing what's
ongoing. To avoid confusion, d.rast chats now.
Yes, I agree that the percentage output needs to stay as it is very
crucial as you point out. I just want to change the GUI in tcltkgrass.
too), are quite inconvenient. Maybe the messages could be directly
printed into a tcltkgrass module window?
| d.rast |
|o Overlay |
window.
This is a good idea! I think I could change it without too much trouble
if somebody could point me to the correct place in the code to make
these changes.
I know how to do this. It is the same technique I will use with the new
initialization code. Basically, separate the interface from the code. So
where G_percent calls fprintf() we replace with something like
DisplayPercent() which will do the proper thing (call fprintf or a
Tcl/Tk function) depending on the current interface. However, I would
not propose this change until 5.1.
So, can anyone give me some pointers in changing the module windows in
tcltkgrass?
Sincerely,
Bangkok, Thailand
